Sitting still and turning the handlebars either way (back and forth) the neck bearings feel dry. (turns fine but not smooth like it should) I am pretty sure it has not been apart and has whats left of the 45 year old grease in it.
I will take it apart later (in the winter) and clean, re-grease, etc as needed.
In the meantime,  is there a trick to get a shot of oil in there to smooth it up a bit? Thanks :umm:
				I'd recommend using tapered steering head bearings and getting rid of the loose balls.
				balls out, time to repack.
ive never been a fan of tapered neck bearing unless the stock races were toast. take tree apart, clean, inspect, then decide. but you need to take it apart, sorry.
				Thanks Mark, I figured that was the only answer. You folks have so many tricks up your sleeves that I had to ask. Thanks!
