The 2-Stroke Garage => Turning Wrenches => Topic started by: gwcrim on October 19, 2019, 12:18:17 PM
Title: Tachometer mount
Post by: gwcrim on October 19, 2019, 12:18:17 PM
Who needs a speedometer?  Not me!
I wanted to mount just the tach.  Simple.  Took a piece of 3/4 inch aluminum, cut to size, drilled a few holes and it's done.  At first, the cup was mounted directly to the aluminum.  Lots of vibration.  So I cut some closed cell foam to use as a cushion.  Nylock nuts hold it snug but not tight.  As soon as the outside temp warms up, I'll test it.
Title: Re: Tachometer mount
Post by: gwcrim on October 19, 2019, 03:37:04 PM
The closed cell foam works great.  Tach doesn't vibrate at all.
Post by: m in sc on October 19, 2019, 06:07:42 PM
ive done that, works well.  :clap:
Post by: Seizer on October 19, 2019, 09:04:05 PM
I used a sheet of carbon fiber. Cut it with a cutoff wheel and then burned up a bunch of drill bits for the bolt holes. That stuff is no joke to drill.
Post by: quocle603 on October 19, 2019, 11:11:36 PM
Will be doing this with my tracker build. Just need to get a cheap small 125 or 200 DB.
