The 2-Stroke Garage => Turning Wrenches => Topic started by: oxford on December 15, 2019, 04:13:27 PM
Title: Shorter clutch cable for clip ons?
Post by: oxford on December 15, 2019, 04:13:27 PM
Anyone have a part number or a different bike application for a shorter clutch cable to use with clip ons?  I know Mark had mentioned using one from a 250 ninja but you have to modify the block.  I'll probably go that route if I can't find a shorter stock cable.
Title: Re: Shorter clutch cable for clip ons?
Post by: m in sc on December 15, 2019, 04:38:18 PM
yup. all you need to do it run an m8 tap thru it.  later you can still use if for a stock cable if you need to revert it back.  :twocents:
Post by: oxford on December 15, 2019, 04:49:11 PM
Is it the 88-07 250s or the 08+ ones?
Post by: m in sc on December 15, 2019, 05:02:54 PM
1st gen ex for sure, i know that works. Cant comment on the 2nd gen.
Post by: Jspooner on December 15, 2019, 05:14:25 PM
Try yambits. Pretty sure they have a clutch cable for "low bars".
Post by: oxford on December 15, 2019, 07:29:39 PM
Quote from: m in sc on December 15, 2019, 05:02:54 PM
Thanks, I'll probably just go this route then.
Quote from: Jspooner on December 15, 2019, 05:14:25 PM
Thanks, had I seen they had one I would have got it from them.  I think I already ordered twice from them.
