The 2-Stroke Garage => Turning Wrenches => Topic started by: rd400greenhorn on January 03, 2020, 11:31:25 AM
Title: clutch springs on tuned engine rd400
Post by: rd400greenhorn on January 03, 2020, 11:31:25 AM
Hi guys
I have mounted stiffer ? clutch springs and the question is, do I go with that or do i 50/50 with normal springs?
Still ongoing project but my motor is tuned with pipes, 34mm carbs, etc
And its going on the road this summer :)
Title: Re: clutch springs on tuned engine rd400
Post by: sav0r (CL MotoTech) on January 03, 2020, 11:48:03 AM
Just use all the same springs.
Post by: quocle603 on January 03, 2020, 05:13:25 PM
check if the springs are the same as the manual recomm. if not, then get new ones that are 10%-15% more stiffer if you want to upgrade.
Post by: rodneya on January 04, 2020, 12:44:46 AM
You can change all, or every second spring. Depended how much a stiffer clutch lever will bother you
