The 2-Stroke Garage => Turning Wrenches => Topic started by: Still biking on March 06, 2020, 04:53:03 AM
Title: Problem with RD 350 fouling one cylinder spark plug at start up
Post by: Still biking on March 06, 2020, 04:53:03 AM
I have an RD 350 which is fouling one spark plug sometimes at start up, same cylinder all the time.  If the bike warms up with out fouling, it runs fine.  Bike has good compression and seals.  Any ideas?  checked timing and cleaned points.
Title: Re: Problem with RD 350 fouling one cylinder spark plug at start up
Post by: Striker1423 on March 06, 2020, 07:45:44 AM
Check your float height and ensure the needle and seat is clean. Too much fuel and you will foul plugs at idle easily.
Post by: SUPERTUNE on March 06, 2020, 09:04:49 AM
Quote from: Striker1423 on March 06, 2020, 07:45:44 AM
Yes, Needle valves cause issues like this.
What cylinder do you have issues with?
Is this on oil pump or premix?
Have you ohm and voltage tested the coils and feed wiring?
Are the plug wires and resistor caps new? If switching over to non-resistor caps you can run resistor spark plugs like a BR8HS.
Don't run both a resistor cap and resistor spark plug.
How modified is the bike and jetting changes done?
Is the charging system working correctly and battery new and in perfect condition?
Could be any of these things.
More info is needed...
Post by: Greaser Greg on March 06, 2020, 08:01:43 PM
I just replaced aftermarket points with Oem and what a difference. Springs are stronger, no wiggle on the post, winds right up. One cylinder was randomly intermittent at idle and no power after six k.
Post by: SUPERTUNE on March 07, 2020, 10:04:49 PM
Quote from: Greaser Greg on March 06, 2020, 08:01:43 PM
Very good point! (Get it? POINTS!!!)  :toot:
That never crosses my mine as I always use Yamaha oem points or aftermarket ignition...
C
Post by: Still biking on March 14, 2020, 03:16:59 PM
Where can you purchase OEM points now?
Post by: SoCal250 on March 14, 2020, 05:01:25 PM
You need to find someone selling NOS inventory. Ebay or a vintage Yamaha parts supplier like Speed & Sport.
RD250 RD350 R5 DS7
278-81621-20-00  (L)
278-81622-20-00  (R)
*See advice from Chuck (http://www.2strokeworld.net/forum/index.php?topic=1637.msg13602#msg13602)
RD400 C/D/E
1A0-81621-20-00 (same part for L & R)
RD400F
2V0-81621-60-00  (L)
2V0-81622-60-00  (R)
(supposedly you can substitute either RD350 or RD400 points depending on type installed by the factory, as there were 2 designs used)
Post by: triple1972 on March 15, 2020, 08:36:53 PM
I was thinking the points were the same on 350 and 400 but backing plate was different. I could be wrong.
Post by: Greaser Greg on March 15, 2020, 10:27:21 PM
There are other models than rd etc that use the same contacts on a different plate. The Oem plates are thicker so once you have two of those you can swap the contacts. There's a recent thread on this site or the air cooled rd club you can find by searching "points" with some info on #'s. Also check the pics on eBay.
https://www.ebay.com/itm/NOS-YAMAHA-CONTACT-BRKR-ASY-1967-YL2-1968-YL2CM-1968-YLCM-1971-CS3C-164-81221-20/232989615583?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Same breaker, different plate. I bought all four of these, but there are others.  First digits of part # is different but they are the same contact breaker for many models.
Post by: SUPERTUNE on March 15, 2020, 11:21:30 PM
Quote from: triple1972 on March 15, 2020, 08:36:53 PM
Yes, different.
I drill out the RD350 plates to fit the 400 points when needed.
