The 2-Stroke Garage => Turning Wrenches => Topic started by: AAAltered on March 21, 2020, 01:03:25 PM
Title: How to clean / restore wiring harness...
Post by: AAAltered on March 21, 2020, 01:03:25 PM
Any tips on cleaning this up before I reinstall?  No known issues with it (worked when removed lol) but it's old.  Connectors have grunge on them.  I was thinking a WD40 bath to start.  Then using contact cleaning spray when re-plugging stuff.
(http://i239.photobucket.com/albums/ff131/aaaltered468/Yamaha%20Rebuild/37A59A55-8085-44B6-B294-8F76E170AA72.jpg) (http://s239.photobucket.com/user/aaaltered468/media/Yamaha%20Rebuild/37A59A55-8085-44B6-B294-8F76E170AA72.jpg.html)
Title: Re: How to clean / restore wiring harness...
Post by: SoCal250 on March 21, 2020, 01:12:18 PM
I have had good success with putting it inside an old pillow case, tying the top closed, then running through the washing machine on gentle cycle with Simple Green.
Post by: m in sc on March 21, 2020, 02:06:05 PM
wd 40 is what i have used.
Post by: Barrie on March 21, 2020, 05:10:59 PM
WD40 has the effect of making the insulation go brittle sometimes,
it's initial effect of cleaning up dirty wiring and removing oily residue from connectors give a good initial result,
but long term draw any moisture out of the plastics making them age.
Post by: RattlecanResto on March 22, 2020, 12:13:46 AM
I throw it in the sonic with diluted simple green
Post by: AAAltered on March 22, 2020, 08:35:06 AM
Hmmmm I have the three liter sonic.  Maybe I'll try stuffing various endpoints in there one at a time....
I've been running it nonstop for the past few days cleaning other stuff from the disassembly.
Post by: m in sc on March 22, 2020, 11:29:53 AM
id recommend after cleaning to use some wd to keep any moisture out of the tight spots. that's -actually- what its designed for.  :twocents:
Post by: Dvsrd on March 22, 2020, 11:30:17 PM
What about known problem areas in stock RD harnesses?  Like the white 3-wire connector block with AC from the alternator (to rectifier) This is known to overheat, and sometimes melt. If I was to use a stock alternator with a stock harness, I'd definitely try to upgrade that particular area.
Also, if using a higher wattage headlight bulb, like 55/60W H4, heavier gauge wiring, or direct feed via relays is a good idea. And the same goes for the power to the coils.
Whenever posdible, I try to use marine grade, tinned wire for any rewiring. Way better than generic automotive wires.
Post by: m in sc on March 23, 2020, 08:57:37 AM
youre right, that is a known problem area.
However (and not being argumentative here)...
Here's why: that's caused from a low battery and people using the alternator to charge a weak or failing battery, this overloads the system. the ratings on the leads and connections are well up to task for a healthy bike used with a healthy battery, even with a 55w halogen in the bucket. Many bikes I had seen in the yard that were otherwise stock that had been there for years before the headlights, etc, started going high-draw halogen have had this issue.
to that point, that's USUALLY  what kills a motorcycle charging system in general, IMHO
However, if you're going to upgrade and modify, i def go with weatherpacks or upgraded connectors where i can.
Post by: AAAltered on March 23, 2020, 10:07:56 AM
Hmmm.  I will be working on the harness today and examine the wiring, especially those noted areas.  I ordered the Economy H4 headlight, that's what I'll be running going forward.
  I am hoping to reuse this harness, the new one for $125 isn't off the table but even with all this bikes been through, none of the issues in the past have come down to the harness/wiring.
Post by: AAAltered on March 23, 2020, 10:36:46 AM
Quote from: SoCal250 on March 21, 2020, 01:12:18 PM
This sounds great.  Not sure I can do this with the wife around though...
Post by: AAAltered on March 23, 2020, 09:33:25 PM
I used the sonic cleaner today on the harness.  I did each section for some time, the hot bath allowed me to pull back all the rubber connector covers.  After I did the whole thing I sprayed with WD40.  I also found contact spray in my stash for reassembly.  For now it's hanging in my utility room for a few days to fully dry out...it looks great overall.
(http://i239.photobucket.com/albums/ff131/aaaltered468/Yamaha%20Rebuild/85FA0224-D8F0-4D71-A03E-BF8AA1EACA80.jpg) (http://s239.photobucket.com/user/aaaltered468/media/Yamaha%20Rebuild/85FA0224-D8F0-4D71-A03E-BF8AA1EACA80.jpg.html)
(http://i239.photobucket.com/albums/ff131/aaaltered468/Yamaha%20Rebuild/F0899A0A-5674-40F8-A9C1-DD1BFD2E88C7.jpg) (http://s239.photobucket.com/user/aaaltered468/media/Yamaha%20Rebuild/F0899A0A-5674-40F8-A9C1-DD1BFD2E88C7.jpg.html)
Bath got pretty dirty:
(http://i239.photobucket.com/albums/ff131/aaaltered468/Yamaha%20Rebuild/3C8B4BC2-A22C-4AC3-9D63-A590F9DB3BD7_1.jpg) (http://s239.photobucket.com/user/aaaltered468/media/Yamaha%20Rebuild/3C8B4BC2-A22C-4AC3-9D63-A590F9DB3BD7_1.jpg.html)
(http://i239.photobucket.com/albums/ff131/aaaltered468/Yamaha%20Rebuild/3A2C8F07-274E-4E37-AA05-FF22193FC756.jpg) (http://s239.photobucket.com/user/aaaltered468/media/Yamaha%20Rebuild/3A2C8F07-274E-4E37-AA05-FF22193FC756.jpg.html)
(http://i239.photobucket.com/albums/ff131/aaaltered468/Yamaha%20Rebuild/E7636BCC-6B85-430B-8C07-EACB8C92C31A.jpg) (http://s239.photobucket.com/user/aaaltered468/media/Yamaha%20Rebuild/E7636BCC-6B85-430B-8C07-EACB8C92C31A.jpg.html)
Post by: SoCal250 on March 23, 2020, 11:33:00 PM
Nice, it looks good
Post by: pdxjim on March 24, 2020, 12:53:20 AM
Looks great!
When reassembling, I always squirt some dielectric grease in the female side of the connector blocks.
Helps to keep the water out and prevent corrosion.  Just a little tho, makes a mess if you put too much.
Post by: 2steve on March 24, 2020, 10:38:01 AM
Quote from: m in sc on March 23, 2020, 08:57:37 AM
REALLY good info there for keeps Mark. I was going to disregard the LED headlight conversion for a while, but now going to move it up to the top.
