The 2-Stroke Garage => Turning Wrenches => Topic started by: rodneya on July 06, 2020, 11:00:59 PM
Title: RD400 rear rotor options
Post by: rodneya on July 06, 2020, 11:00:59 PM
Is there a different rear brake rotor option for a RD400?
Offset is not important as I do not plan on running a stock caliper setup
Title: Re: RD400 rear rotor options
Post by: m in sc on July 06, 2020, 11:35:48 PM
thinner? xs400 or daytona style single piece rotor. unless you want to go smaller, then there's all sorts of options if you can fabricate. danny ran some dirtbike on on his bike, made a different hat for it
Post by: rodneya on July 06, 2020, 11:55:05 PM
Yes, thinner and preferably smaller and drilled or slotted. But Trying to get a one off part fabricated around here is not easy, so preferably something read made
Post by: Dvsrd on July 07, 2020, 06:11:17 AM
Quote from: rodneya on July 06, 2020, 11:55:05 PM
www.isrbrakes.se. Swedish quality Steel. Good though for Eddie Lawson and Yamaha back in the day.
And check out their rear caliper with integrated bracket.  About as light as it can possibly be.
http://isrbrakes.se/products/calipers/22-029.html
http://isrbrakes.se/products/brakediscs/
Not cheap and chinese made, but then you get what you pay for........
Post by: waktaylor on July 07, 2020, 08:39:23 AM
https://ebcbrakesdirect.com/motorcycle
You can find specs on that site and cross ref other rotors. I believe front and rear are the same on daytona but not sure about the regular rd400.
Kyle
Post by: m in sc on July 07, 2020, 08:56:50 AM
they are the same as well.
at -some- point i plan on making a hat and using a smaller rotor & caliper on the rd for the rear.
Post by: Dvsrd on July 07, 2020, 03:20:57 PM
Quote from: m in sc on July 07, 2020, 08:56:50 AM
Good plan :)  I would think 200 mm diameter and 4 mm think should be more than sufficient.
If I was looking for a used setup, something from a 125 cc sportbike would be at the top of the list. Aprilia 125, Italian built Yamaha models, Cagiva Mito,  etc.
Post by: m in sc on July 07, 2020, 03:46:28 PM
i might use a stock front grom rotor. dirt cheap.
Post by: rodneya on July 21, 2020, 06:04:38 PM
I tried to find the inside diameter of a grom rotor and what I could find it seemed to small .
Also need a rotor with 3 or 6 holes to fit nicely if you make a hat to suite the 6 stock holes.
Newer RS rotors are 3 hole and 210mm diameter so should work with a small Brembo caliper.
Is there really any difference if the caliper is on top or underneath if its connected to the swingarm?
Im thinking to put it underneath and use a torque arm to the stock connector under the swingarm.
Post by: m in sc on July 21, 2020, 07:51:23 PM
oh I'd make a hat. under is technically better, lower center of gravity.
