The 2-Stroke Garage => Turning Wrenches => Topic started by: rd400greenhorn on July 17, 2020, 01:25:38 AM
Title: Raw engine cases, how do you treat Them
Post by: rd400greenhorn on July 17, 2020, 01:25:38 AM
So, got My rd400 engine cases water polished
How do I go about treating Them, Any experince?
Should i just heat clear coat Them a bit and leave it at that?
FUI i do like aluminium colour and or silver spray for engine cases
Title: Re: Raw engine cases, how do you treat Them
Post by: m in sc on July 17, 2020, 09:18:17 AM
mine were vapor honed a few years ago (4+). still look great.  before assembly, i sprayed them brake clean, dried, then sprayed with wd40 and wiped them down. this keeps the pores from oxidizing.  i then cleaned the case halves where they seal with lacquer thinner on a rag, then assembled. id never paint them.
cerakote? different story, id def do that. i think danny did that to his frame, but it looks great on aluminum too.
Post by: rd400greenhorn on July 17, 2020, 09:26:11 AM
Okay, thats interesting. So just wd 40 and it stays nice
Might consider that for sure :)
Post by: AAAltered on July 17, 2020, 09:50:17 AM
About five years ago I did Cericoat on pipes, it looked great *but* did not stand the test of time.  Maybe cases would be different...
Before coating
(https://i.ibb.co/J3Zczff/9-EE1-ECB4-F373-4053-9757-DF7-C6-DF80-E3-A.jpg)
After coating
(https://i.ibb.co/Fgq2gQY/40-C75-F6-C-2-C3-D-4758-ABE1-6-C3-F609-EC2-BD.jpg)
About five years later
(https://i.ibb.co/7gxdJjs/3-BD82429-DDCD-4-D99-9-B05-FC52-B1074828.jpg)
Post by: Jspooner on July 17, 2020, 10:40:24 AM
I bead blast all of my cases when I do a rebuild. I don't treat them with anything and I haven't seen any issues. Of course it's really going to depend on the environment they are in most of the time. Where I live it's typically pretty dry most of the time and my bikes stay inside. If you live near salt water or in real humid air most of the time then I suppose you could have issues.
Post by: m in sc on July 17, 2020, 10:46:20 AM
not a great picture, but took  this last weekend when i repaired the water pump mount which was causing a huge oil leak. I think these cases were done 7? years ago. its been a while. sprayed bottom with brake clean after i fixed leak.
:twocents:
Post by: m in sc on July 17, 2020, 10:54:41 AM
top of same case a few weeks ago
(http://www.2strokeworld.net/wp-content/uploads/LC-HYBRID/2020/20200618_202919-rotated.jpg)
Post by: Organicjedi on July 17, 2020, 10:59:27 AM
I think they are fine to leave them raw and just give them a good clean with degreaser  and some brushes/ rags every now again.
I would not be opposed to a clear ceramic coating if you want to get fancy. Of course you can do many colors with ceramic coating, but my preference is the raw aluminum look on the cases.
The real advantage to the ceramic coating is corrosion resitance and it will ease cleaning a bit. But aluminum is pretty corrosion resistant itself. So you have to ask if the extra cost is worth it.
Post by: rodneya on July 17, 2020, 11:05:30 AM
I clear coated my last set of cases. I was going to get them vapor blasted, but it is quite pricey around here, and I decided to spend the 3 to 400 dollars on parts instead.
I cleaned them up with a bit of soda blasting at home and a wire brush. After the clear coat you cant see the brushed finish anymore and even the slight color differences in the metal show up.
I used a clearcoat made for aluminum and a 3 stage cleaning / prep process to make sure it sticks
Post by: patastinky on July 17, 2020, 11:32:29 AM
I used a degreaser and a rag. I like the "used" look.  :celebrate:
Post by: pdxjim on July 17, 2020, 01:06:27 PM
ACF50 or WD40 after vapor blasting
Post by: Kawtriplefreak on July 17, 2020, 02:45:22 PM
I bead blast with #80 glass beads. Then spray down with carb cleaner. After assembly for spot cleaning I use a shop rag soaked in carb cleaner.
Post by: sav0r (CL MotoTech) on July 17, 2020, 08:22:16 PM
Maybe it's just me but I don't like vapor blasted aluminum. It's unnaturally clean.
Post by: rodneya on July 17, 2020, 09:53:30 PM
Quote from: sav0r on July 17, 2020, 08:22:16 PM
I kinda like the look, just the cost to get it done near me is crazy
Post by: rd400greenhorn on July 18, 2020, 02:55:59 AM
Yeah i know what your saying. Looks almost fake, Its so clean 😂
But got i cheap, and old timer offered it at his own garage, soit was cheap and easy do get done. He offered me a beer as we behold the clean cases before i left, iam still surprised and happy the kind of People i get to meet via the commen interest in motorcycles.
Definately gonna be water polishing some more stuff in the future 😁
Post by: pdxjim on July 19, 2020, 02:49:36 AM
I love it.
