Hello
Trying to figure out where do these hook up ? Any idea? These are under the gas tank.
(https://imgur.com/a/d4hT2KZ)
Brown and brown/white are flasher relay
Black should just go to ground
Quote from: rodneya on October 08, 2020, 02:57:52 PM
Should I then hook up the brown and brown white together? I'll ground the black. Thanks.
Yamaha Wiring Diagrams (http://www.2strokeworld.net/forum/index.php?topic=35.msg92#msg92)
Do you turn signals and a flasher? If so, then like what rodneya says, the brown/white and brown go to the 2 wires of the flasher.
bn/w is the feed from the flasher to the turn signal switch. brown is switched power. black is ground.
Thanks guys. Will do that. Getting close to starting her up.
