The 2-Stroke Garage => Turning Wrenches => Topic started by: Striker1423 on March 15, 2021, 03:37:04 PM
Title: TDR Reeds Not Sealing
Post by: Striker1423 on March 15, 2021, 03:37:04 PM
Just as the title states, I have a visible gap with the TDR reeds I picked up on my Rd350 modified reed cages. I understand that reeds don't close all the way when running, but I also hear if they seal good they lend to easier starting. I have tried sanding down the reed block a bit to see if it helps, but I'm gaining little traction and don't want to mess it up. I still have the stock metal reeds and if needs be I'll just run those.
Anyone have any tips?
Title: Re: TDR Reeds Not Sealing
Post by: rodneya on March 16, 2021, 11:44:49 AM
Can you flip them over?
Post by: Striker1423 on March 16, 2021, 03:50:38 PM
Quote from: rodneya on March 16, 2021, 11:44:49 AM
They are flat. I'
m gonna try and flex them a bit and see.
Post by: m in sc on March 16, 2021, 04:00:50 PM
dont.
clean the reedcage and suck on the carb side, they will seal shut quick. if that works, they are good. this is a common occurrence.
also make sure the screws arent too tight. use blue loctite and just seat them. they are what? m4? M3? I mean, an m6 is 6-7 ft lbs. those are probably supposed to be 3 or 4. things to consider.
Post by: 2t Fan on March 16, 2021, 11:13:01 PM
Quote from: Striker1423 on March 15, 2021, 03:37:04 PM
I have noticed the same with Boyesens, tried the same route but not much change. So fixed as it is
Post by: Striker1423 on March 17, 2021, 09:22:13 AM
I just snugged the screws up. I can try just seating he screws until the split washer just collapses and regoop so loctite on them.
Just nervous about losing a screw into the motor.
Post by: m in sc on March 17, 2021, 10:18:26 AM
i understand that for sure.
Post by: soonerbillz on March 17, 2021, 04:58:04 PM
The reeds on my CR were having problems sealing. A buddy of mine in Sweden made me some carbon fiber ones and it worked beautifully.
When I build up my RD250 I'll have him make some for that motor.
Post by: 85RZwade on March 17, 2021, 11:54:54 PM
I wish I had a Swedish buddy who made carbon fiber reeds...
Post by: soonerbillz on March 18, 2021, 08:46:52 AM
Quote from: 85RZwade on March 17, 2021, 11:54:54 PM
Well I'm sure there others in the USA doing the same.. we just ended up both needing them.
