Are the YDS7 & R5 carb slides the same ?
I know the part numbers show the be the same.. but is there differences between the two?
My bike is a R5 frame but it has the TDS7 lower motor. It had a set of cables with caps and slides but I have no idea what they had going on as the top end and carbs were MIA.
Same part between the models, although Left & Right are not the same. Double check that both sides have the same number stamped in them (should be inside the bottom) for the cutaway. Should be a 2.0 cutaway for DS7 & R5, as shown in the part numbers below
278-14112-20-00 Throttle valve, L
278-14113-20-00 Throttle valve, R
EDIT: I've attached a photo of a 2.0 slide showing the cutaway number
Quote from: SoCal250 on April 26, 2021, 03:36:13 PM
Same part between the models, although Left & Right are not the same. Double check that both sides have the same number stamped in them (should be inside the top) for the cutaway. Should be a 2.0 cutaway for DS7 & R5, as shown in the part numbers below
Ok.. Thanks. I'll take a look at them tonight!
