The 2-Stroke Garage => Turning Wrenches => Topic started by: rd400greenhorn on May 07, 2021, 12:08:53 PM
Title: Help regarding cylinders / new pistons rd400
Post by: rd400greenhorn on May 07, 2021, 12:08:53 PM
So, got these 2 set of cylinders measured. Fresh bore but can i get pistons to fit?
1 set measures 64,90 mm
1 set measures 66,10 mm
Anyone?
Or do I need to rebore and hone 🤷‍♂️
Title: Re: Help regarding cylinders / new pistons rd400
Post by: Yamaha 179 on May 07, 2021, 12:23:25 PM
Wossner sells RZ pistons sized 64.19mm and 66.44mm.  I don't know about Wiseco but I think they sell 65.00mm pistons also.
Lyn Garland
Post by: rd400greenhorn on May 07, 2021, 01:24:03 PM
Thanks.
So would they fit, i Mean wirth tolerances?
Post by: Dvsrd on May 07, 2021, 04:23:53 PM
64.90 must be a worn out 64.75 nominal bore. No direct fit piston to my knowledge.
66.10 must be a somewhat worn 66.00 nominal bore. 0.10 or more in clearance may be too much.
If it is possible to bore to 66.25 or higher, and pistons are available, it may still have some life left.
Have you measured at several locations, and fore-aft as well as side to side?
Post by: rodneya on May 07, 2021, 06:00:20 PM
Where did you measure the bores, and what did you use to measure?
Post by: Alain2 on May 07, 2021, 07:13:02 PM
You will need rebore.
Why were the cylinders freshly bored to these seizes?
Post by: SoCal250 on May 07, 2021, 09:54:38 PM
^^ what Alain2 said
The normal procedure is to acquire the pistons, and then provide them to the shop performing the boring so the cylinders can be bored/honed to the correct clearances for the new pistons.
Post by: rd400greenhorn on May 08, 2021, 02:46:58 AM
Well you dont really remove materiel with a hone and the cylinders came with pistons in, gone now, so thought maybe i can judt find new pistons and be done with it.
Unfortunately not. They were measured with digital gauge, at s pro workshop.
Post by: hayduke on May 08, 2021, 11:03:26 AM
My dusty memory is 66mm is the max overbore on RD400's, Wiseco offers a 66mm piston, which may be about right for your 66.1 cylinders. The 64.9mm cylinders are probably too loose for a 64.75mm piston and will probably need to be bored to 65.25, as a 65mm bore may not get all the cylinder wall
2¢
Post by: Alain2 on May 08, 2021, 11:26:06 AM
Quote from: hayduke on May 08, 2021, 11:03:26 AM
A 66.10mm bore is already too big for a 66mm Wiseco piston.
Post by: 1976RD400C on May 08, 2021, 07:31:01 PM
Wiseco Pro Lite RZ350 pistons have a 66.25 and 66.50 size. They work well in a RD400.
