The 2-Stroke Garage => Turning Wrenches => Topic started by: mewherman on July 01, 2021, 04:33:08 PM
Title: Transmission oil dipstick
Post by: mewherman on July 01, 2021, 04:33:08 PM
I've drained my old transmission oil out and started refilling it, it says 1500ccs on the side cover, but I've only put in a quart and the dipstick is saying it's grossly overfilled? Or am I reading the dipstick wrong?? I had fully drained the transmission.
Title: Re: Transmission oil dipstick
Post by: m in sc on July 01, 2021, 04:39:14 PM
rock bike back and forth and let sit a bit. check on center-stand up at least level.  you can fire it up real quick let it spin around, then settle and check.
i usually follow the dipstick level, never let me down yet.  I aim for the middle to 3/4 when cold.
Post by: mewherman on July 01, 2021, 04:44:57 PM
Quote from: m in sc on July 01, 2021, 04:39:14 PM
The dipstick has a section that has been flattened, and I am assuming that's the full mark, otherwise it has no markings on it. By 3/4 do you mean the entire length of the dipstick or of that flattened portion of the dipstick?
Post by: Milan on July 01, 2021, 04:47:36 PM
I got some covers off of Ebay as spares.
They came with the dip sticks.
Took them out & they were 2 different lengths.
Check you have the right stick, and keep the CC's measured.
As above spin it & let sit & re-check.
M
Post by: m in sc on July 01, 2021, 04:55:20 PM
YES FLAT SECTION IS THE  'check ' section. top of the flat is full, bottom is low.
I can say this much: I know it will -survive- with only 1 qt in from dry. But don't tempt fate.  :devil:
Post by: mewherman on July 01, 2021, 06:30:39 PM
So I ran the engine and this sucked the oil down to the appropriate level, and I was able to add the remaining oil. I guess it needs to run to fill the whole case? I probably already discovered this when I changed the transmission oil last and had forgotten about it because it was like 5 years ago.
Either way, I measured all my dipsticks, and they're all the same length.
Post by: Jspooner on July 01, 2021, 11:02:09 PM
I go by the CCs. Roughly 1-1/2 quarts if you can't measure it exact.
Post by: rodneya on July 01, 2021, 11:04:52 PM
Dont screw the dipstick in when checking.
I just fill up the recommended amount and use the dipstick to check level now and again.
I have had a few bikes previously where the dipstick or check hole were way off. YZ250 oil check hole is probably an inch low.
