The 2-Stroke Garage => Turning Wrenches => Topic started by: soonerbillz on January 27, 2022, 06:19:45 PM
Title: Head stock Lock removal
Post by: soonerbillz on January 27, 2022, 06:19:45 PM
Has this been discussed before? I searched but found nothing.
I need to remove this before I send the frame off for blasting and coating.
Oh BTW. No key.
Title: Re: Head stock Lock removal
Post by: rodneya on January 27, 2022, 06:49:31 PM
the little cover just has a pin holding it in that can be prised out carefully.
With out a key you will have to drill out the lock part.
They are not easy to get out even wit a key after being in there for soo long
Post by: pidjones on January 27, 2022, 06:59:51 PM
Yes, even with a key mine would not come out. Decided to just leave it be.
Post by: soonerbillz on January 27, 2022, 07:37:22 PM
Does anyone make a replacement?
Post by: m in sc on January 27, 2022, 08:10:26 PM
nope. tape over it before sending to powder coater. will survive ok
Post by: rodneya on January 27, 2022, 09:19:09 PM
Quote from: soonerbillz on January 27, 2022, 07:37:22 PM
You should be able to find a new old stock one on ebay.
Post by: Striker1423 on January 27, 2022, 09:48:04 PM
Quote from: m in sc on January 27, 2022, 08:10:26 PM
Mine melted remember? If I remembered the post I'd link to it.
I just closed the cover and pretended I didn't see it. Lol don't know how I'd get it out now.
Post by: m in sc on January 27, 2022, 11:50:17 PM
jeez how hot did they bake it? lol.
Post by: Striker1423 on January 28, 2022, 07:59:15 AM
Hot apparently lol.
Post by: 1976RD400C on January 28, 2022, 08:25:32 AM
Why don't you get a key for that number lock and try it?
Post by: soonerbillz on January 28, 2022, 11:08:01 AM
Quote from: 1976RD400C on January 28, 2022, 08:25:32 AM
Where do I get that?
Post by: RDFL on January 28, 2022, 11:46:57 AM
Any locksmith, if you don't want to go to local many on ebay.  https://www.ebay.com/itm/184518307469
Post by: soonerbillz on January 28, 2022, 12:12:05 PM
I have one that did my Mustang and even a tractor lock for me.
Honestly I didn't even think of that..duh.
Post by: KANDY on January 28, 2022, 12:18:17 PM
Quote from: Striker1423 on January 27, 2022, 09:48:04 PM
:dawg:
Post by: SoCal250 on January 28, 2022, 12:42:53 PM
Quote from: soonerbillz on January 28, 2022, 11:08:01 AM
I've had good luck with NOS Yamaha pre-cut keys off Ebay. As posted above just order by stamped lock number
If you end up drilling it out and need a replacement assembly & key, those are avialable too in either OEM NOS or repro. Check Ebay.
Post by: m in sc on January 28, 2022, 02:09:23 PM
my point is powder coating ovens shouldn't really ever get over 600 degrees (usually less). that's way, WAY under what brass, aluminum and zinc go liquid at.  Striker, did they powedrcoat yours with the oven in self cleaning mode? lol.   :boom:
Post by: Striker1423 on January 29, 2022, 04:02:00 PM
Quote from: m in sc on January 28, 2022, 02:09:23 PM
No idea, its just all stuffed full of crap. The little door wouldn't open, so I razor knifed around it and it still wouldn't budge. Finally got it open and well. Here:
https://imgur.com/gallery/aJBRAjZ
Post by: 1976RD400C on January 29, 2022, 08:17:23 PM
Quote from: Striker1423 on January 29, 2022, 04:02:00 PM
Maybe they ruined that lock when they were cleaning it, putting it in a caustic tank or something like that?????
Post by: m in sc on January 29, 2022, 08:59:02 PM
as a side note, worked on matts bike today, rd400. the rubber drive bushings on the rear wheel survived the powedercoater and oven.. so the tank chemicals make sense as a reason the lock melted.  :twocents:
Post by: Striker1423 on January 29, 2022, 09:34:30 PM
Ohhh maybe. Would also make sense as to why it was rusting a bit too.
