The 2-Stroke Garage => Turning Wrenches => Topic started by: Milan on April 08, 2022, 09:01:17 AM
Title: Weisco Pistond for Rebuild
Post by: Milan on April 08, 2022, 09:01:17 AM
In the Craigslist / Ebay section there area few Daytona's listed.
One of them has the engine rebuilt using the Weisco Forged pistons.
I know there have been some discussions about these here & on AC Club.
Some fights about them as well.
Has anyone here used these and had longevity with them.
M
Title: Re: Weisco Pistond for Rebuild
Post by: soonerbillz on April 08, 2022, 09:15:27 AM
Don't know about longevity because I've not finished the build as yet but my  R5 build and top end has been designed around Wiseco forged pistons.
This is what was decided on after lots of discussion with John Ritter.
I'm hoping for a long, happy top end life.
Post by: Milan on April 08, 2022, 09:23:57 AM
Most of the discussions I have read, have to do with the tolerances of the bore due to the pistons being forged.
Due to their different expansion properties
M
Post by: m in sc on April 08, 2022, 09:59:43 AM
i dont like them personally but no issues with longevity as long, as mentioned, the cyls were bored correclty..  :twocents:
Post by: rodneya on April 08, 2022, 10:19:24 AM
Will also depend on if you allow the motor to warm up well every time before riding.
Post by: 1976RD400C on April 08, 2022, 04:32:36 PM
I've been using Wiscco 513 RZ350 pistons for 10 years. They are lighter than the ones listed for RD350. I replaced them once when the clearance got to .005" and I think the second set may be that much now. I'm going for a rebore soon. They are a little lighter than OEM and seem wicked strong.
Post by: Alain2 on April 13, 2022, 08:27:11 AM
Quote from: 1976RD400C on April 08, 2022, 04:32:36 PM
How many miles did you get out of the pistons before hitting 0.005" of clearance?
Post by: 1976RD400C on April 13, 2022, 09:46:45 AM
[/quote]
[/quote]
I can only estimate, 6 years, 2000 miles, 4 track days, with a hot rod motor that has big ports. I would call it very hard use. The fresh bore had the clearance set to .003" to be on the safe side.
Post by: Striker1423 on April 13, 2022, 11:19:46 AM
On a bad chamfer job (from next reputable engine builder who assessed it) with a fresh bore at 3 thou, the Wiseco's got me just past 2000 miles before I killed it on the freeway at 75-85mph for 40 miles.
Note to self: RD250 (350 top end) does not like that.
Post by: Milan on April 13, 2022, 11:38:47 AM
So possible solution:
Find some Yamaha pistons & replace the Wisecos.
M
Post by: m in sc on April 13, 2022, 12:08:03 PM
i'll be honest, ive never been a fan of wisecos. you hear them making noise: they are wearing. period. and yes, i have bikes with them unfortunately.  I get it on a race bike. but most people will be just fine with art cast pistons, or if you have to go forged, vertex is a better option IMHO.   :twocents:
Post by: Milan on April 13, 2022, 12:12:51 PM
So in a perfect scenario:
Remove the Wiseco pistons.
Measure
If OK
swap in a 1'st overbore yamaha piston & rings
M
Post by: m in sc on April 13, 2022, 01:19:06 PM
depends on personal preference.  wiseco and oem cast pistons have different tolerances so you cant just 'swap' them, the bores need to be set for that piston.
Post by: soonerbillz on April 13, 2022, 05:07:33 PM
Quote from: m in sc on April 13, 2022, 01:19:06 PM
Fact. It took special work to make John happy with the ones he set up for my R5.
Post by: Hawaii-Mike on April 13, 2022, 05:36:27 PM
Gary at Spec2 preferred Wiseco as well and then he found out Fast From the Past sells Wossner and he did some work for the owner.  My H2 motor is running great with 2000+ miles, no piston slap.  More than I can say for Wiseco.
For RD's Gary still prefers Pro-X unless you're racing.
Post by: 1976RD400C on April 14, 2022, 08:12:50 AM
Probably the only reason to use forged is if you have a modified motor with porting for high rpm, big reeds and carbs, and a light rotor. If you miss a shift or it doesn't go into gear all the way and jumps out at full throttle, the rpms can go so high a cast piston can break.
Post by: m in sc on April 14, 2022, 10:14:40 AM
I'll be honest, never much of an issue in the triples i had. Just don't care for them in the RDs
Post by: Alain2 on April 14, 2022, 12:11:46 PM
My two 1979 RD400 have Wiseco forged pistons. Both bikes had the cylinders bored to the recommended Wiseco specs. I have limited experience with 2 stroke engines so consider that. My experience is that the pistons will slap until you heat them up, I found that if your tune is rich, or if you don't ride hard enough, the pistons never get hot enough to fill the larger clearance and this could lead to premature wear.
One bike was initially tuned rich and after approximately 3000km was showing clearance of 0.0045" to 0.005", mostly from cylinder wear (front to back and in the lower portion of the cylinders). I honed the cylinders, put new rings, leaned the tune and put another 2000km on them. At this point the bike could only be ridden hot or it would slap. It was smooth as butter on highway when showing +320f CHT. The last 2000km added a little bit of wear to the bottom of the cylinders, front to back. The pistons also added a little bit of wear, anyway at that time I was measuring a total clearance of 0.005-0.006" and decided to stop there for now. Ring gaps were 0.017-0.018" for the top and 0.020-0.021" for the bottom, absolutely no sign of blow by.
Believe it or not, I decided to hone it again (no rebore) and I put new pistons (Wiseco) in these worn out cylinders, I have 2400km on them at the moment, I will open the engine at the end of this summer, unless the engine open itself! It shows 115-120psi compression, no sign of blow by.
The other bike was tuned leaner from the beginning and has 10000km on the pistons, but I seriously think it needs rebore. (Rings were replaced once) This bike is parked at the moment until I decide what to do.
