The 2-Stroke Garage => General Chatter => Topic started by: Milan on April 22, 2022, 02:36:25 PM
Title: RD Fuse Block
Post by: Milan on April 22, 2022, 02:36:25 PM
Had loose fuse on RD
Went to tighten the clips, and one broke off.
Top right of pic
Searched the web.
Does anyone know where to get these crimp on holders.
https://www.dropbox.com/s/kl1oalbhmjbr1ql/Fuse%20Block.jpg?dl=0 (https://www.dropbox.com/s/kl1oalbhmjbr1ql/Fuse%20Block.jpg?dl=0)
M
Title: Re: RD Fuse Block
Post by: Kawtriplefreak on April 22, 2022, 02:41:31 PM
https://www.ebay.com/itm/323480093362?fits=Model%3ARD350%7CMake%3AYamaha&hash=item4b50ea82b2:g:HigAAOSwINxbtHSC
Here's a whole assembly. $15.
Post by: Milan on April 22, 2022, 02:51:21 PM
Just added link to above post.
Pic wont post
Main 4 fuse box.
M
Post by: SoCal250 on April 22, 2022, 03:24:50 PM
A few years back I had the same issue and tried to find the same style terminals to rebuild the OEM block, but was unsuccessful.
If one contact broke others will probably follow. Things tend to fall apart after 40+ years -- both bike parts and people.
Your best bet is likely to be replacement of the entire fuse block with a new unit.
https://www.economycycle.com/shop/yamaha-rd250350400r5ds6ds7-parts/electrical-ignitions-lighting/electrical-parts-and-related/fuse-blockholders/yamaha-rd400all-fuse-block/
EDIT: If you find suitable replacement holder components for the OEM block please post it here.
Post by: Milan on April 22, 2022, 03:41:32 PM
I looked for that.
Unfortunately that harness is wrapped up with 2 other ones and then routed around back for plug in.
So I could get a new block & just leave the wires = but that would drive me crazy.
So I would have to unwrap them
Yep, the others broke as well
Maybe modify a female spade connector to try & hold.
Or these:
https://www.amazon.com/Magic-shell-Plated-Holder-Ceramic/dp/B07Z7HTHRL/ref=sr_1_10?crid=32MEXHY3ZMA9A&keywords=circuit+board+fuse+connectors&qid=1650656380&sprefix=circuitboard+fuse+connectors%2Caps%2C89&sr=8-10 (https://www.amazon.com/Magic-shell-Plated-Holder-Ceramic/dp/B07Z7HTHRL/ref=sr_1_10?crid=32MEXHY3ZMA9A&keywords=circuit+board+fuse+connectors&qid=1650656380&sprefix=circuitboard+fuse+connectors%2Caps%2C89&sr=8-10)
& put a screw thru the base into the existing
Post by: Milan on April 22, 2022, 06:06:12 PM
Used a female connector.
M
