The 2-Stroke Garage => Turning Wrenches => Topic started by: rodneya on April 28, 2019, 01:13:02 AM
Title: Stinger lengths
Post by: rodneya on April 28, 2019, 01:13:02 AM
Can somebody explain how the stinger lengths work in GP pipes (both silencers on same side)
The outer pipe has a much shorter stinger than the inside pipe.
I can find a lot of info on stinger diameter and length, but not on using two different lengths together
Title: Re: Stinger lengths
Post by: Jspooner on April 28, 2019, 01:29:07 AM
I am not 100% sure but I think they compensate for that in the rest of the chamber design.
Post by: rodneya on April 28, 2019, 02:24:49 PM
Its been a long time since I made my own pipe from A graham bells book, but if I remember correct the stinger diameter was based on a percentage of the inlet pipe and the length 12 times the diameter.
Post by: Dvsrd on April 28, 2019, 03:47:50 PM
It could be that the stinger that appears to be shorter, just extends into the chamber. Or that the stinger diameter is oversize, and only a shorter internal flow restriction is doing anything.
Post by: teazer on April 28, 2019, 09:02:46 PM
Or could be that stinger length is a lot less critical than we think.   Just puttin' that out there. :eek:
Post by: pdxjim on April 29, 2019, 01:25:40 AM
I had always assumed the rest of the stinger was inside the belly.
Never cut any pipes open to find out tho.
Post by: Dvsrd on April 29, 2019, 04:37:08 AM
A cheap inspection " endoscope" with a flexible extension would be easier than cutting pipes open. And very handy for other 2 stroke stuff, like looking at color of the bottom side of piston crown. Just pull carbs/ reeds instead of entire top end.  Something like this:
https://m.banggood.com/no/3-in-1-7mm-6LED-Waterproof-Borescope-Android-USB-Type-C-Port-Borescope-Inspection-Camera-p-1152981.html?gmcCountry=NO&currency=NOK&cur_warehouse=CN&createTmp=1&ID=45763&utm_source=googleshopping&utm_medium=cpc_union&utm_content=2zou&utm_campaign=ssc-no-all-0302&ad_id=337428064977&gclid=EAIaIQobChMIvdOG6PL04QIVxKSaCh3EdwDMEAQYCCABEgKMefD_BwE
