The 2-Stroke Garage => Turning Wrenches => Topic started by: RD4140 on November 02, 2022, 02:55:20 PM
Title: What is THE most basic ignition / electrical setup to get bike running?
Post by: RD4140 on November 02, 2022, 02:55:20 PM
(1970 R5)
Back on my project, long story short but I need to figure out the easiest way to actually get the ignition set up and running. I've got a pretty good basic knowledge but have never started from scratch.
Being that my bike has basically zero electrics right now and anything on there is damaged, I was figuring buying the vape system was a good start point.
Anyone got any tips for a really basic wiring set up incorporating the vape ignition, a kill switch, key switch, a battery, fuse, and where to ground to etc?
Title: Re: What is THE most basic ignition / electrical setup to get bike running?
Post by: m in sc on November 02, 2022, 03:10:16 PM
most of it is in the vape, so its easy. hell, you could get it running w just what's in the kit..
that being said, IF you plan to run a battery, i would get a NC relay, and connect that to the blue kill wire on the coil. then switce the power to the battery to turn the whole bike on and off, when off, that relay grounding the coil and shuttign the motor down.
if you want even MORE basic,  just get a one wire bar mounted kill switch and attach that to the blue coil wire. then its just ignition and nothing else.
Post by: RD4140 on November 03, 2022, 03:18:42 AM
Right on, okay. Ill get the Vape installed and then see what else I need.
Cheers.
