The 2-Stroke Garage => Turning Wrenches => Topic started by: LMS on March 25, 2023, 06:11:02 PM
Title: Right side control switch question
Post by: LMS on March 25, 2023, 06:11:02 PM
Where would this black wire plug into? I would assume it plugs into ground but want to make sure as I can't find a black wire in the wiring diagram associated with this switch.
Thanks.
Title: Re: Right side control switch question
Post by: 1976RD400C on March 26, 2023, 08:52:39 AM
On the switch I have that black wire is attached to the housing of the switch and the wiring diagram doesn't show it connects to the wire harness on the bike. I don't think you need to connect it to ground because the engine stop and light switches on that right side switch assemble don't need any ground connection.
Post by: LMS on March 26, 2023, 09:55:09 AM
I just took apart the switch and yep, same thing, attached to the body of the switch. I marked every wire when I took them all off, guessing the tape fell off. There is an open 4-point connector within the rat's nest, two are for the blinkers, one for the headlight, one open slot. These connect to ground on the headlight, I think it was connected to that one open spot.
Thanks for clarifying.
Post by: 1976RD400C on March 26, 2023, 10:19:50 AM
After thinking a bit more, that may be to make sure the whole handlebar is grounded so the horn switch on the left side works because that needs a ground to work.
