The 2-Stroke Garage => General Chatter => Topic started by: LMS on April 04, 2023, 09:05:07 AM
Title: Painting ABS plastic seat pan???
Post by: LMS on April 04, 2023, 09:05:07 AM
I bought an ABS 'paint ready' seat pan and I have no idea what, 'paint ready' means. I would assume that I would just scuff the pan and shoot it with the base color? This is not the pan I have, but it's the same material...
https://www.mikesxs.net/bug-eye-cafe-racer-seat-pan-abs-plastic.html
With some plastics, you shoot it with adhesion promotors, flexible primer, etc.
Anyone painted one of these?
thx.
Title: Re: Painting ABS plastic seat pan???
Post by: m in sc on April 04, 2023, 11:28:06 AM
i would suggest vinyl dye spray or bumper paint.. but why bother?
Post by: pidjones on April 04, 2023, 01:05:09 PM
99% of motorcycle fairings are ABS these days, I believe. I usually start with rattle-can etching primer, then lacquer or water-born color, then 2k clear.
Post by: LMS on April 04, 2023, 03:18:33 PM
Why bother, because I'm painting the tank and seat pan the same color. Believe me, they make the abs look great in pictures, but there are tiny imperfections all through out.
Found a 'few' how-too after posting this, but it seems like all painters have their own technique. I'll start by testing the underside with scuffing, etc. to see how it fares.
Thanks.
Post by: m in sc on April 04, 2023, 03:48:50 PM
reason i asked is, can you see the pan when its on the bike?
Post by: IR8D8R on April 04, 2023, 04:34:29 PM
ABS should be rigid plastic. Prep and primer would be more important on ABS I think. If you don't get it degreased thoroughly it will peel. "Paint surface cleaner" like 'Finish1' after 600 grit and scotch brite.
Car painters used to use a "flex-add" additive for Firebird noses, Fieros, and Saturn body panels, but that Enduroflex was some kind of FRP, urethane, and rubber sandwich. Paint would crack if it didn't have the additive. Insurance body shops always left it out and your paint cracked and peeled.
I tried some of the Krylon spray paint made specifically for plastic on Lexan. It didn't stick. I complained to Krylon and they sent me a big box of the same stuff that didn't work. Like 20 cans of spray paint. I appreciated the effort but...
Post by: LMS on April 04, 2023, 04:38:22 PM
Quote from: m in sc on April 04, 2023, 03:48:50 PM
Yep, it kind of looks like the one I posted. The sides under where the cushion attaches can be seen along with the hump on the back.
Post by: LMS on April 04, 2023, 04:45:56 PM
Quote from: IR8D8R on April 04, 2023, 04:34:29 PM
Yep, it's pretty rigid. Thanks for the tips. I was reading to clean, clean, and clean some more, then clean again because when they inject these, I guess mold/dirt, grease can be a huge issue.
Sooooo, scuff with gray pads along with scuff paste. Clean again, follow with anti-static wipes, then adhesion promotor, prime, paint. What a pain.
Post by: m in sc on April 04, 2023, 09:14:04 PM
ahh, i missed the link the 1st time. my bad.
Post by: pidjones on April 05, 2023, 06:30:31 AM
Just be careful with solvents. ABS is dissolved in acetone to make ABS cement. I use soap and water, rinse well, dry, then 91% isopropyl alcohol to clean. Lacquers (like many rattle-can primers) attach well because they have solvents like acetone in them. Need 2k clear to hold up, though.
Post by: rodneya on April 05, 2023, 10:17:24 AM
Clean, scuff slightly and then spray a coat of adhesion promoter before priming.
Post by: LMS on April 09, 2023, 06:26:02 AM
Thanks all. I have a pretty good plan now, fingers crossed this works out.
Post by: LMS on April 29, 2026, 11:07:39 AM
Three years later, took cover off bike last weekend and the painted seat pan crazed. Pretty sure it's due to extreme heat and cold in my garage and the abs shrinking and expanding along with the paint. But really, this should not happen as most bikes these days have tons of abs on them. So maybe it was my prep/paint, who knows. The tank and fender are fine. Now, try and strip 2k clear, 2 base colors, primer and filler and you get a seat that looks like it went through the ringer. You can't just use aircraft stripper, or it will eat the abs. Applied three light coats of primer. Just smeared glazing putty, will have to sand that, prime, smear more. Then use high build primer, block, etc. What a frickn pain.
Post by: JKV45 on April 29, 2026, 11:42:54 AM
Quote from: LMS on April 29, 2026, 11:07:39 AMThree years later, took cover off bike last weekend and the painted seat pan crazed. Pretty sure it's due to extreme heat and cold in my garage and the abs shrinking and expanding along with the paint. But really, this should not happen as most bikes these days have tons of abs on them. So maybe it was my prep/paint, who knows. The tank and fender are fine. Now, try and strip 2k clear, 2 base colors, primer and filler and you get a seat that looks like it went through the ringer. You can't just use aircraft stripper, or it will eat the abs. Applied three light coats of primer. Just smeared glazing putty, will have to sand that, prime, smear more. Then use high build primer, block, etc. What a frickn pain.
Most likely there was just too much material on it.  With most surface coatings - less is more.
The thinnest build you can get and still get a smooth finish is usually the most durable.
Post by: LMS on April 29, 2026, 12:12:19 PM
I hear ya. And that was one of the original issues. The seat pan was supposedly, ready to paint. My ass it was. There were so many imperfections in the abs, no way primer was going to fill it. And now it's worse than before. Oh well. The seat can be taken off pretty easily. I think I'll just store it inside during the hot days, and all during winter when the garage gets down to single digits.
Post by: oxford on May 01, 2026, 08:29:03 PM
Quote from: IR8D8R on April 04, 2023, 04:34:29 PMI tried some of the Krylon spray paint made specifically for plastic on Lexan. It didn't stick. I complained to Krylon and they sent me a big box of the same stuff that didn't work. Like 20 cans of spray paint. I appreciated the effort but...
I've had good luck with Krylon fusion paint in the past.  Black plastic trim on cars and modern dirtbike plastics.
On the dirt bike plastics it even held up decent to branches and whatnot in the woods.  It didn't hold up to high rub areas like where boots/legs rubbed on it.
Post by: Aaron Russell on May 02, 2026, 12:02:27 AM
I just crudely painted a plastic fender for my bike so I dont know how well it would hold up but I just scuffed it up, put glazing putty on some spots, and sprayed it with some old black paint I had, still have some spots to sand.
As far as Krylon goes, I have Krylon's John Deer Yellow on my bike. Had some issues but I think that was just poor prep I just have it cleared with 2k and its holding up decent, really any spot falling apart is my fault.
Post by: JKV45 on May 02, 2026, 08:44:38 AM
Quote from: Aaron Russell on May 02, 2026, 12:02:27 AMI just crudely painted a plastic fender for my bike so I dont know how well it would hold up but I just scuffed it up, put glazing putty on some spots, and sprayed it with some old black paint I had, still have some spots to sand.
As far as Krylon goes, I have Krylon's John Deer Yellow on my bike. Had some issues but I think that was just poor prep I just have it cleared with 2k and its holding up decent, really any spot falling apart is my fauly.
That's the secret for a really good DIY paintjob, especially on cycle tanks.  It will stand up to gas splashes, unlike standard clear.
I did a repair on an ABS fairing with a Duplicolor base and SprayMax 2K gloss clear - and I was impressed.  The clear needs a good amount to flow, but it did flow nicely and never dulled.
I've also used the SprayMax 2K satin black on a few parts I couldn't powder coat.
Post by: LMS on May 03, 2026, 04:32:04 PM
I'm laying down the high fill primer now. Took a bit of time to prime, then use glazing putty, prime, putty, over and over. I'm hoping to block it tomorrow or Tuesday, then lay down the black base. Tape, then lay down the red and clear. The weather here has been the pits, so it's slow going. Plus, I'm taking my time with the drying process. Last time i did all pretty fast and i might have not let certain elements dry enough.
Post by: rodneya on May 03, 2026, 06:05:25 PM
What type of primer and paint did you use on it?
Post by: LMS on May 06, 2026, 10:35:03 AM
I used SEM rattle can primer and spraymax 2k last time. Using the same this time, except this time I'm going to use sealer before paint, not just fill primer. I think that was the issue the first time, no sealer primer.
Post by: rodneya on May 06, 2026, 07:34:16 PM
Quote from: LMS on May 06, 2026, 10:35:03 AMI used SEM rattle can primer and spraymax 2k last time. Using the same this time, except this time I'm going to use sealer before paint, not just fill primer. I think that was the issue the first time, no sealer primer.
Looks like that SEM primer is self etching. I would use something else as that last time I painted my bike the paont supplier told me not to use self etching primer with 2K paint as they react to each other.
Post by: LMS on June 05, 2026, 10:33:22 AM
It took a bit of time, but I finished.  I'll take metal any day. Prepping plastic like this is a pain in the ass. I did everything. Went out the next day after I wet sanded it and it cracked overnight.  Stripped it again, which is a royal pain, and used all Krylon primer, not a mis-mash of different products.  First, adhesion promoter, then primer. Then spot filled areas. And sealed it.  All the primer was gray, but the primer on the tank and fender were black.  Sprayed black, waited 2 days, taped and sprayed red.  Forgot to order clear, whoops. So, I had to scuff it, and I scuffed through a few spots.  More black touch up and clear.  Came out ok after sitting in bathroom with heater for 24 hours.  The Mrs. was not happy. The problem, the red isn't as deep as on the tank because of the gray primer.  Oh well.
I'll take a pic when I put it on this weekend. Time to ride it. Hope to God it fires and runs ok as I didn't pull the carbs.
Post by: m in sc on June 05, 2026, 10:48:10 AM
looks good.  ill be doing similar soon w a solo cowl for the tzr
Post by: LMS on June 20, 2026, 12:34:02 PM
All that work, same paint can, and the seat is a lighter shade of red than the tank and fender. Goes to show what black vs grey primer can and will do.
