Started up the Daytona yesterday, after about 3 weeks.
It stared right up after about 4 kicks. Ran fine.
Turned the choke Off, and the right side shut off.
I guess it is mad at me for not starting it regularly
Time to clean the carbs.
Used only Non-Ethanol fuel.
Any other comments on why?
M
clogged pilots
non ethanol fuel clogs too, carb cleaner has been around a LOT longer than ethanol has. :gentleman:
Do a check on fuel flow out of petcock also. Starving for fuel. Check to rule out .
Quote from: m in sc on May 01, 2023, 12:57:10 PM
Plus two on that!
