The 2-Stroke Garage => General Chatter => Topic started by: Milan on June 14, 2023, 11:19:23 AM
Title: Battery Draining
Post by: Milan on June 14, 2023, 11:19:23 AM
So I have a bike, that every 3 - 4 days the battery is going dead.
so there is a short somewhere.
Or a part that is not working.
I will start at the battery & follow the wiring.
This topic has been posted before, so was there a common cause for this?
M
Title: Re: Battery Draining
Post by: m in sc on June 14, 2023, 11:49:04 AM
unplug the regulator and let it sit, check voltage in a few days. if they short internally can cause a drain. they are cheap and readily available as well. regulator/rectifier is on the RH side under the body panel on the sub frame. if that's not it, check the key switch.
