Does anyone know of a aftermarket one or one that I could get at a automotive store. Mine is gone or I would measure it.
McMaster Carr or MSC catalog has many listings for sizes, even MSC has metric ones.
Thank you Chuck I will check it out , I am hoping to find one local as the bike is ready to start for the first time. I am so ready, this has been a long project #basketcase
Not sure if those will stand up to the gasoline as well. Try getting a vinton o ring that will fit the float bowl, they will hold up to the gasoline. I would suggest getting one online because you'll know it will hold up and won't have an issue with fitting.
Quote from: quocle603 on May 27, 2019, 09:22:15 PM
Not sure if those will stand up to the gasoline as well. Try getting a Viton o-ring that will fit the float bowl, they will hold up to the gasoline. I would suggest getting one online because you'll know it will hold up and won't have an issue with fitting.
Fixed it for you...
C
Quote from: SUPERTUNE on May 27, 2019, 10:43:03 PM
Thanks
