The 2-Stroke Garage => Turning Wrenches => Topic started by: Karl squire on October 05, 2023, 01:24:31 PM
Title: WOT Plug chop
Post by: Karl squire on October 05, 2023, 01:24:31 PM
I would like an opinion on this as I'm bit confused, I have read its the color and also its how thick the band is , I heard it should be 1mm thick and I have heard 2mm thick and I heard Coffee colour and I have heard Cholate Brown I have 3 pics of WOT for just over a mile. would like some opinions on this plug if nobody minds. This all the same plug just rolled it over to show differnt sides.
Title: Re: WOT Plug chop
Post by: m in sc on October 05, 2023, 01:51:08 PM
looks good to me. hows it running?
Post by: Karl squire on October 05, 2023, 03:14:26 PM
Quote from: m in sc on October 05, 2023, 01:51:08 PMlooks good to me. hows it running?
Seems to be running good, I'm 180lbs got it over 100 mph a couple of times, when the power band comes on at about , not sure of the rpm, lifts the front wheel a wee bit even with clubman bars so my weight is shifted forward a bit, seems pretty good. I think its running as it should be to be honest. Maybe the mid range a bit rich but maybe not its probably close enough.
Post by: Karl squire on October 05, 2023, 03:18:39 PM
Thanks so much for your help, you got me through this, it turned out well, even with Chinese Cylinders and pistons, I'm pleasantly surprised.
Post by: 1976RD400C on October 06, 2023, 10:26:00 AM
A little more run time and I bet it will look more like this with the 1-2mm ring and brown showing up.
(https://i.ibb.co/HtWFJZt/plugchop.jpg) (https://imgbb.com/)
Post by: Karl squire on October 07, 2023, 07:11:04 AM
Quote from: 1976RD400C on October 06, 2023, 10:26:00 AMA little more run time and I bet it will look more like this with the 1-2mm ring and brown showing up.
That plug looks perfect, no ?
