The left side cover of my RD400 where the shift shaft comes through had worn into an oval allowing far too much play in the shifter. Yesterday, m in sc and I (okay mostly him) used his mill at work to open that hole up and sleeve it. A tack weld to keep it in place and some paint and it looks like it was manufactured this way.
Good, simple design to solve a frustrating problem. Thanks Mark!
Very nice fix
fwiw, thats a 12mm id shock bushing that came with some shocks.
Very nice!
Do this too, if you haven't already: https://www.2strokeworld.net/forum/index.php?topic=4779.msg40779#msg40779
https://www.2strokeworld.net/forum/index.php?topic=4779.msg40779#msg40779 (https://www.2strokeworld.net/forum/index.php?topic=4779.msg40779#msg40779)
you get the cover bushed you dont need that. that's a bandaid for the problem we solved on matts bike.
is the zirk/grease fitting still functional with bush in place there?
YES, after the bushing was pressed in it was drilled and deburred. :toot:
