cleaning the carbs.
Got to the point of getting the needle & nozzle out.
Lot of mechanical stuff there.
I have not done this before, so what is the minimum needed to disconnect to get the slides out. Dont want to screw up something
M
There are two Philips screws that hold the slide in by the actuating arm plate. Pull those and the arm will move up and out, then the slide will come out. But that is also how you get the needle out....so not sure how you got the needles out of the slides without pulling the slides. They should just slide out if disconnected...
I will try that.
Did not get needles out yet, either.
M
