The 2-Stroke Garage => Turning Wrenches => Topic started by: RD350NL on June 18, 2025, 03:50:39 PM
Title: Confused by wiring
Post by: RD350NL on June 18, 2025, 03:50:39 PM
Hi all
I'm a bit puzzled how the turn indicator light should function. FYI This bike is new to me and the light didnt ever work since I have it.
Situation: All 4 blinkers flash but the turn signal light doesnt flash.
What I checked: Put 12v straight on the wiring to the indicator light (ground + 12v) and the light came up.
I checked the wiring diagram but it looks like there isn't any ground going to the turn signal indicator bulb. How is this supposed to function? From the looks of it 1 wire is for left positive, 1 for right positive, but where does the ground come from?
Thanks for the insights already..
Title: Re: Confused by wiring
Post by: m in sc on June 18, 2025, 04:20:57 PM
the indicator needs to be an incandescent bulb. ( if it's just 1) one leg goes to the left hot ts wire, the other goes to the rh hotvwire. hot wire is the 12v feed to the turn signal. dark bn & dk green. my tzr is the same fyi. it doesn't have a ground, persay. 4th bulb up from bottom, correct? green and bn wires
Post by: RD350NL on June 19, 2025, 12:42:18 AM
Thanks, that clarifies!
Post by: Pravin on June 27, 2025, 06:51:19 AM
Quote from: m in sc on June 18, 2025, 04:20:57 PMthe indicator needs to be an incandescent bulb. ( if it's just 1) one leg goes to the left hot ts wire, the other goes to the rh hotvwire. hot wire is the 12v feed to the turn signal. dark bn & dk green. my tzr is the same fyi. it doesn't have a ground, persay. 4th bulb up from bottom, correct? green and bn wires
Yes we do the same way in India as well , the Indicator picks ground from one leg and power from opp depending up on where you flip the indicator switch
