Hello Experts ,
I am struggling on Rear brake due to worn out Rear wheel Hub and cost of importing quality Brake shoes every 5k run as she's my daily ride...
I was thinking of converting in to rear disc but keeping the Spoked wheels due to the look of it : )
Is there any option of doing this ? what parts I need like Rear Disc Hub spoked one , caliper , rotor, Mounting etc and what bike spares will be compatible ?
Seeking advise here : )
Cheers ,
Pravin Dalvi
very expensive. I've done it, not worth it aside from looks. get a fresh drum hub and ride the rear brake less?
Quote from: m in sc on July 01, 2025, 10:38:41 AMvery expensive. I've done it, not worth it aside from looks. get a fresh drum hub and ride the rear brake less?
Thanks SC for the quick advise ;) I'll stay away from this thought for now and look for a good condition rear hub ..
Cheers
Pravin
To get an idea of the cost, there is a spoked disk hub from a Euro spec rd400 for sale on facebook in Michigan for $600.
You will still need spokes, caliper, hanger, spacers and modified parts to fit the 350 swinger
... or buy a complete spoked RD250/400 wheel from the UK or Europe.
Shipping will be the bite there.
Quote from: Pravin on July 01, 2025, 10:32:46 AMBrake shoes every 5k run
That's a lot of brake shoe wear! :eek: Are you sure you're not resting your foot on the pedal while cruising?
Quote from: SoCal250 on July 01, 2025, 08:56:40 PMQuote from: Pravin on July 01, 2025, 10:32:46 AMBrake shoes every 5k run
Due to the worne out drum the balw shoes also wear out fast and before bottoming out brakes stop working cas the drm is out
I think from all the advises above sourcing a good rear drum will solve my problem
it will. imho it would be cheaper to retrofit a modern motocross rear hub but only if you had access to a good fabricator or could do it yourself, if you were going disc rear. I can dobthat kind of work and it literally wasn't worth my time when I did it, and went w the rd hub. I've never wanted to add a disc since to projects after it really was no functional benefit, to me. 0.02
Quote from: m in sc on July 02, 2025, 02:45:18 PMit will. imho it would be cheaper to retrofit a modern motocross rear hub but only if you had access to a good fabricator or could do it yourself, if you were going disc rear. I can dobthat kind of work and it literally wasn't worth my time when I did it, and went w the rd hub. I've never wanted to add a disc since to projects after it really was no functional benefit, to me. 0.02
makes Sense SC , I don't fancy rear disc , Just wanted to solve the issue once for all but looking at the work and expenses better I be on Drums : )
Cheers,
Pravin
