The 2-Stroke Garage => Turning Wrenches => Topic started by: Vintagewannabe on September 16, 2025, 04:44:30 PM
Title: Wandering chain tension
Post by: Vintagewannabe on September 16, 2025, 04:44:30 PM
So I have a 520 conversion kit on my 73 RD350, bought from economy cycle with a DID ert3 chain. The setup has about 500 miles on it.
So my problem is that at one point in the chain, my slack will be at 1 1/4", another 1 3/8, and at its tightest 3/4".
I thought at first that it was the chain, but I am beginning to think rear sprocket. I marked the sprocket, and as I roll the wheel around, every time the sprocket is at the same point, the chain gets tight, regardless of where it falls on the chain. If I just spin the wheel around say 180°, the chain loosens up.
Has anyone experienced this? I talked to economy cycle and he said they have never run into this issue.
 The wheel is aligned, chain is straight, tire is centered in the swingarm.
I checked the runout of the sprocket by putting a ziptie on the swingarm, and a section of about 12 teeth would contact the ziptie, then the rest would be about 1mm or less from touching. I dont know if this is acceptable because I have never checked one, just trying to see if I can find my issue. I can include pics if someone thinks I may have something there
Title: Re: Wandering chain tension
Post by: m in sc on September 16, 2025, 07:06:02 PM
sounds like might be the cush drive rubbers failing. also check the carrier bearing
Post by: quocle603 on September 16, 2025, 07:57:18 PM
I had this similar issue on another bike. I believe it was a warped sprocket. Ended up changing it and it resolved it. Your conversion kit is probably new, but doesnt hurt to check if its true
Post by: Vintagewannabe on September 16, 2025, 09:53:52 PM
The cush drive is new, and is pretty tight. I checked the drive for any play around the axle or any deflection,  but I can check again.
quocle603, the conversion kit is new, but how do you mean to check if its true?
I am also considering just getting another sprocket and trying that as well
Post by: pdxjim on September 17, 2025, 01:37:17 AM
Pretty common in my experience.
Make sure the axle adjusters are even, the chain run is straight, and split the difference.
The tight bit will wear faster than the loose bit, and it'll all even out in the end.
Post by: Vintagewannabe on September 17, 2025, 09:39:46 AM
Quote from: pdxjim on September 17, 2025, 01:37:17 AMPretty common in my experience.
all of that is even, and the chain and sprockets are all straight and aligned.
How many times have you seen tjis work out? The only time I have run into it was a worn out chain that was not maintained.
Post by: paul1478 on September 17, 2025, 10:25:05 AM
for my bike, it was the swingarm bushings...
Post by: RDnuTZ on September 17, 2025, 10:40:08 AM
I've had it many times with worn chains on my dirt bikes. As noted above chains don't always stretch evenly.
Post by: 1976RD400C on September 17, 2025, 10:42:06 AM
That doesn't seem like something to worry about. I would adjust the chain so it has 1 1/2" at the tight spot. Then put it on the center stand and spin the wheel by hand and watch the lower run of the chain and if it's not moving up and down more than 1/2" I think you're good.
Post by: m in sc on September 17, 2025, 11:08:31 AM
I agree.  if everything else is good just lube it and run it.
Post by: klaird on September 17, 2025, 11:23:13 AM
Check you front sprocket too.  I had a similar problem and it turned out the splines were not in the center of the front sprocket.
Post by: Simoniz on September 17, 2025, 11:40:21 AM
I had this on my RD250LC back in the 1980s, and was puzzled by it too. Turned out the rear wheel bearings were collapsing. Get your back wheel off and put in new bearings to correct it.
Post by: sav0r (CL MotoTech) on September 17, 2025, 12:00:11 PM
This thread deserves a sticky. It's a good resource for chain tension issues. Many great places to look that don't necessarily come to mind immediately. At least for me.
My two cents is that I always adjust tension to the tight spot. If the tight spot is egregious, then I try to spot the issue. A sticky link for example. Though eccentric sprockets have been found too.
Post by: Vintagewannabe on September 17, 2025, 01:51:38 PM
I will doulbe check the bearings and front sprocket. One of my worries about just adjusting for the loose spot, is that it would be so loose on other spots it might drag on the swingarm, and these are not set up for that. Also if the sprocket is the problem, would it. Not just continue making the chain worse?
I haven't found any sticky spots in the chain yet, but I can double check.
Post by: quocle603 on September 17, 2025, 02:23:01 PM
Quote from: Vintagewannabe on September 16, 2025, 09:53:52 PMThe cush drive is new, and is pretty tight. I checked the drive for any play around the axle or any deflection,  but I can check again.
You can always put a dial indicator to it to see if there is any major run out. I would just lay it on some glass to see if it isnt warped.
Good luck. It seems like there other possible reasons from others.
Post by: SoCal250 on September 17, 2025, 02:27:59 PM
To rule out manufacturing issues (defects) with the chain you can measure sections of 10-14 links with calipers in different spots around the chain. Compare the section where it's tight to where it is looser. If it's not the chain then you have radial runout on one (or both) of the sprockets.
Post by: Vintagewannabe on September 17, 2025, 03:27:58 PM
Quote from: SoCal250 on September 17, 2025, 02:27:59 PMTo rule out manufacturing issues (defects) with the chain you can measure sections of 10-14 links with calipers in different spots around the chain. Compare the section where it's tight to where it is looser. If it's not the chain then you have radial runout on one (or both) of the sprockets.
This is my plan for my next move, as well as putting the wheel on a truing stand and checking sprocket runout in all directions, and checking bearings.
Post by: Vintagewannabe on September 23, 2025, 10:30:43 AM
So I pulled the rear wheel, and checked the sprocket, and bearings. Wheel bearings were perfect, cush drive is still good, looks like my carrier bearing has a bit of play, like if you were to try and twist the carrier on the axle, same way you check wheel bearings on the bike.
So once I had the wheel on the truing stand, I checked the sprocket and it acted out of round. Sat the wheel on the ground, and realized that around the carrier, inside the center bore of the rear sprocket there was a large gap on one side and none on the other. The taller area fell between the two green dots I made, which falls in line with all the slack in the sprocket being on that side.
So I pulled the rear sprocket and the center bore of the sprocket was 1mm larger than the hub on the sprocket carrier. Any other sprocket I have fitted has been a tight fit, but this one is definitely not, but I did not think much of it at time of install.
I have it back together, and now there is a much smaller variation in chain tension. About 1/4 in or less, vs the 3/4 it was.
Has anyone else had a sprocket that loose on the hub? I'm thinking of just ordering a custom one from sprocket specialists.
Post by: m in sc on September 23, 2025, 10:37:49 AM
actually, no but that def explains it. you always want the sprocket to be hubcentric.  if that's from economy, reach out to John. also, look into rebel gears, they may have one as well
Post by: JKV45 on September 23, 2025, 11:33:04 AM
Quote from: Vintagewannabe on September 23, 2025, 10:30:43 AMSo I pulled the rear wheel, and checked the sprocket, and bearings. Wheel bearings were perfect, cush drive is still good, looks like my carrier bearing has a bit of play, like if you were to try and twist the carrier on the axle, same way you check wheel bearings on the bike.
Based on what you have posted previously, it appears to me that the sprocket has been the issue.
Not sure if you turned it 180 degrees when you reinstalled it, but there's a chance that could improve the inconsistent tension.
It seems like that sprocket is out of spec in a few ways.
Post by: Vintagewannabe on September 23, 2025, 12:39:11 PM
I am pretty dead set that the sprocket is my problem.
I didn't spin the sprocket, I just centered that extra slop that it has. I am going to make some calls to see if the numbers I got line up with the specs that economy cycle has, and the manufacturer rebel gears.
Post by: 1976RD400C on September 23, 2025, 02:03:30 PM
It certainly shouldn't have to rely on the bolts to center it, it needs the hub to fit, like rotors and wheels on a car.
Post by: RDnuTZ on September 23, 2025, 04:21:14 PM
automotive wheel lug nuts are tapered on 1 end which does help center the wheel  :umm:
Post by: m in sc on September 23, 2025, 07:47:48 PM
there used to be bolt centric wheels,, or were more common  vw vugs come to mind. but the taper nuts are there so the load is spread out better. and not against the threads.  also a tapered nut has less chance of backing off. hub centric, way better  0.02
Post by: Simoniz on September 24, 2025, 08:57:42 AM
Good to see you found the solution to the weirdness. It's unusual to see one like this that is too big in the center. At least sprockets are easy to replace.
Post by: Vintagewannabe on May 18, 2026, 12:37:27 PM
So I am finally getting back on this issue after life getting in the way. I reached out to economy cycle a few times and didn't really get anywhere.
Talked to rebel gears and they said my sprocket was to spec and they have never had this issue with the RD350 sprockets. Has anyone else had this? The bike came to me bone stock so I doubt whe wheel was swapped or machined but its not impossible.
Post by: RDnuTZ on May 18, 2026, 02:38:31 PM
do you have another sprocket laying around to swap on there for a sanity check?
Post by: Vintagewannabe on May 18, 2026, 02:52:46 PM
Quote from: RDnuTZ on May 18, 2026, 02:38:31 PMdo you have another sprocket laying around to swap on there for a sanity check?
theres a small chance I still have the sprocket that was on it but I need to dig around. My engine needs a rebuild so I will at least pull the sprocket and re measure everything then.
Post by: Vintagewannabe on May 19, 2026, 08:23:50 AM
Dug out the old probably stock sprocket. Center bore measures exactly 74. Which is also what JT sprocket says on their site. I think I will call sprocket specialists in the morning and see what they have as spec.
Post by: 1976RD400C on May 19, 2026, 10:31:49 AM
Took a look at a sprocket I had. The hole in oem sprocket fits tightly over a machined hub on the sprocket carrier. It is exactly 74mm in diameter. That centers it. That hub is only 1/2 as thick/tall as the sprocket so it looks like a gap between the two until you take the sprocket off.
Post by: Vintagewannabe on May 19, 2026, 11:03:40 AM
Quote from: 1976RD400C on May 19, 2026, 10:31:49 AMTook a look at a sprocket I had. The hole in oem sprocket fits tightly over a machined hub on the sprocket carrier. It is exactly 74mm in diameter. That centers it. That hub is only 1/2 as thick/tall as the sprocket so it looks like a gap between the two until you take the sprocket off.
Mine was the same way.
I called sprocket specialists and their spec is 74.37mm.
I am going to pull my sprocket apart again and re-measure to see if I got something wrong.
Post by: 1976RD400C on May 19, 2026, 11:18:54 AM
An oem sprocket hole is exactly 74mm
Post by: Economy Cycle John on May 19, 2026, 07:06:23 PM
I measured several here were all 74mm. No other reports of issues with that batch or any with this issue, so not sure what happened here. The one you have is 75mm?
Post by: Vintagewannabe on May 20, 2026, 03:37:36 PM
I pulled the wheel and measured everything. The hub the sprocket sits on measures from 73.05 to 73.18 depending on where you measure. The sprocket center bore measures 74.35.
I put the carrier on a truing stand and I am a bit worried the carrier is out if round. Thinking back when I first got the bike, the rear sprocket was loose one day. I will post a couple pictures but there is a lip on the carrier where the sprocket sits that makes me worried the sprocket was loose for a long time and hurt the carrier.
I talked to rebel gears again, and since they are only an hour from me, they said I could bring my sprockets and carrier and they would help me figure it out.
Post by: Vintagewannabe on May 20, 2026, 07:35:16 PM
https://youtube.com/shorts/tr7hSFRzvts?si=GzzMYRXzE8qEHzHs
So these show the lip on the carrier that looks like strange wear.
The vid is just to show how much play there it.
I rolled the dice on an ebay part so we'll see if it is different.
Post by: 1976RD400C on May 21, 2026, 08:40:23 AM
The oem parts I have are a tight fit, in fact I couldn't pull the sprocket off by hand after removing the bolts. Had to tap it with a brass hammer to get it to pop off.
Post by: RDnuTZ on May 21, 2026, 10:23:46 AM
Quote from: Vintagewannabe on May 20, 2026, 07:35:16 PM20260520_092436.jpg
I suspect the fleabay part will solve the discrepancy. A SWAG on what happened to current 1? A previous clueless owner probably ran the bike without the lock tabs and never bothered to check the nuts were secure on there leading to lots of back-and-forth movement of sprocket.
Post by: Vintagewannabe on October 12, 2026, 10:34:27 PM
Was looking through posts and realized I never came back to this one!
The ebay carrier fixed it! Almost no play on the carrier, and no more random chain tension.
I remember when I first got this bike running and riding, I was messing with something and found the sprocket loose! And that was with lock tabs secured, so theres no telling how that went down.
Post by: RDnuTZ on October 13, 2026, 10:23:29 AM
:olaf: fleabay can be a valuable resource at times.
