I've been digging into swing arm options for an RD350. This is all assuming the drum brake remains intact. I can turn wrenches, cut shit, and hit things with a hammer, but I have no ability or capability to machine, weld, or fab. The MotoLanna alloy swing arm for the SR, TT, XS, etc looks especially sexy for the price.
I email MotoLanna to ask if they are aware if their swing arm has successfully been installed on an RD. Attached is the response I received.
At the frame side, all I need is a 400 pivot bolt and some bearings and thrust washers. Shiiit.....can't be that easy, can it?
Assuming it is that easy at the frame side, and aside from a possibly a longer chain, linkage modification, what else should I investigate at the wheel side? SR/XS wheels or spacers if needed? Surely someone has gambled $300 on one of these and seen it through on a 400 or 350. :twocents: :twocents:
Quite a few members here have done the MotoLanna arm on RDs. If you search the site you'll come up with a bunch of threads. There's also an aftermarket swingarm thread in the Tech Library.
https://www.2strokeworld.net/forum/index.php?topic=415.msg2782#msg2782
https://www.2strokeworld.net/forum/index.php?topic=4211.0
I put one in my 350 frame; all I needed was a spacer on each side. I'll be entering the realm of the experimental with a TDR hub at the other end.
Thanks @85RZWade. All you needed was the RD400 pivot bolt and the 6.5mm (16mm ID) frame spacers (and inner pivot bolt bushing/tube)?
I assume the stock 350 wheel hasn't been tried, although it looks like the rear axle is wider in diameter than stock 350. The TDR hub will look delicious :thumbs:
(https://i.postimg.cc/C51TsmJ1/79C8D149-CDCA-4137-B24B-9A7163DF66EA.jpg)
I used the 350 pivot bolt and bushing; I think the swingarm came with bearings. It was easy.
Looks really nice! I have a few questions though:
How is the length compared to a stock RD350 or RD400 swing arm?
How does the weight compare to a stock swing arm?
Is the RD350/400 wheel axle long enough?
Is the shock mount in the same position as stock, measured from swing arm pivot?
:umm: I think Striker has my original 350 swingarm a few states away, so I have no answers for you. I MIGHT still have a 350 axle around...
@SmokeAddicted
her the link where we discussed the Motolana arms. You will find the dimensions and weight in that thread. https://www.2strokeworld.net/forum/index.php?topic=2174.msg22868#msg22868
Regards Uwe
everyone i went to order one they were out of stock. this was a few yes ago
Mark,
it is the same now. Since a couple of month sold out
Regards Uwe
:taz:
my 72 R5 could def use one. :metal:
Anyone able to confirm if stock 350 wheel/wheel axle is useable? The picture looks like a different axle w some spacer bits, but worth asking.
**Pic was from Rodneya in a previously referenced thread.
@SmokeAddicted
Axle come with the Motolanna swingarm.
Regards Uwe
Quote from: stresa on January 25, 2026, 06:18:04 AM@SmokeAddicted
Regards Uwe
I can confirm this.
I actually have my old 350 arm yours replaced Wade, and I have an RD400 swingarm I acquired off eBay for cheap years back now. I can line them up and take measurements too if someone needs it?
