The 2-Stroke Garage => Turning Wrenches => Topic started by: MRDRcycle on July 10, 2019, 05:51:30 PM
Title: DG pipe Installation - RD350
Post by: MRDRcycle on July 10, 2019, 05:51:30 PM
Hello,
I just got a new set of DG's for my 73' RD 350. I installed one chamber easily to the rear foot rest bracket (inside the frame) just as the instructions say. However, the other pipe (kickstand side) hits the frame near the rear sprocket and will not reach the bracket if I try installing it the same way.
I'm thinking a section of the pipe may have been welded in the wrong position - it shouldn't be this difficult :umm:. Do some folks install these pipes on the outside of the frame vs. inside?
I'm thinking I may have to return these, but am going to give it another try. Any help here would be much appreciated.
Title: Re: DG pipe Installation - RD350
Post by: suey1958 on July 10, 2019, 06:15:26 PM
I have those DG's on a 75 model (should be the same) Mine are mounted on the inside of the Passenger peg bracket. I am pretty sure thats the only way to mount them.
Post by: RDryan on July 10, 2019, 07:03:54 PM
Hi, that's what I'm running now the DG pipes on my 75' RD250. I kinda wonder the same thing though in regards to install, they take a bit of persuading with the rubber mallet. Mounting tabs for both sides are on the inside of passenger peg mount brackets. When I fitted mine I left the cylinder flange/mounts bolt loosely, if that helps. They weren't easy to fit and too look at them  from the rear you can see that they differ in relational distance to the rest of the bike.
Post by: Czakky on July 10, 2019, 07:09:03 PM
Those passenger brackets are known to be bent. FWIW
Post by: MRDRcycle on July 10, 2019, 07:11:51 PM
Thanks everyone! I'll give it a shot.
Post by: SUPERTUNE on July 10, 2019, 10:23:32 PM
I make my own rubber 1/16th rubber washers and go to Ace Hardware and get 8mm allen bolts with nylock nuts and fender washers to mount pipes on RD's. Just leave some play in them as the nyloc's will stay on.
