(https://i.postimg.cc/mrhXWHZt/7668A87F-9052-4B38-974E-231C1092E051.jpg)
My long-suffering RZ is next on the lift; time to address the mag-side crank seal that failed prematurely at 25-ish years of service.
(https://i.postimg.cc/9fSxmQzd/IMG-3406.jpg)
Disassembly has been straightforward; always a challenge not to make a huge mess while draining transmission oil and coolant at the same time. I find that the more effort I make to prevent a mess, the larger the mess I make. This applies to so many life situations...
(https://i.postimg.cc/zBgxVYgm/IMG-3407.jpg)
This has to be the last RZ350 in the world with all original electronics; they all still work (OK, the catalytic converter module is long-gone, and the battery eliminator isn't OEM) but since this is going to probably turn into a crank-up refresh, perhaps an updated ignition is in the cards.
(https://i.postimg.cc/gjmRy4J6/RZ1.jpg)
Ahh, the glory years. This would have been 1987 and my Mom's driveway. A day trip home form college with a new girlfriend (now my lovely wife) and a new Pirelli on the rear. That tire never did inspire confidence.
(https://i.postimg.cc/HWhvhbPP/34881982-444C-46B7-B2F7-A19177A8F133.jpg)
Part of the plan is my long-anticipated suspension & brake "upgrade" to this (FZR?) swingarm and CBR wheels/forks/brakes. It only brings the bike forward in time about a decade and probably adds weight...but I love the look of those white 5 spoke wheels.
(https://i.postimg.cc/FHtW9Nvy/77CAF5AB-4D7C-4B40-A0E9-B13DA131182E.jpg)
The barn, the hay and most of the CBR are now gone, and we shall see how the bits and bobs I have left mate up with the old RZ.
My original electronics are safely stored away. Turns out, they were working just fine. A 1985 like yours.
Wondering how long the factory cat pipes could function right with continuous oil soaking.
I'm happy with the Zeel from Economy Cycle though. Best wishes for your refresh success.
"I'm happy with the Zeel from Economy Cycle though. Best wishes for your refresh success."
Thanks; I think either the Zeel or Toomey's product would be my choice.
(https://i.postimg.cc/d0VNNBjn/IMG-3426.jpg)
The lump came out without fuss; what a nasty, dirty thing. I used to keep this bike spotless, but something changed along the way :confusing2:
(https://i.postimg.cc/VNzPfnBr/IMG-3427.jpg)
This engine is a junkyard dog that I built up mostly from eBay, and I don't remember the head damage.
(https://i.postimg.cc/DwrK3BsJ/IMG-3428.jpg)
Looking OK so far...
(https://i.postimg.cc/CM737R0f/image.jpg)
They've been in there a minute. Rings are free.
(https://i.postimg.cc/Hx2h6hqH/image.jpg)
Yikes. This could have been bad. Right side cylinder, outside transfer port. I see this failure on V-twin lawnmower engine sump gaskets pretty often, where it only causes an oil leak.
(https://i.postimg.cc/W33GPYDs/image.jpg)
The Haase method.
(https://i.postimg.cc/ncYGBmfg/image.jpg)
Check this out! Have you ever seen a prettier wrist pin? It came out easily; I only needed the internal pliers, not the pin puller. I look forward to your evaluations.
(https://i.postimg.cc/L4vzsptj/image.jpg)
I couldn't capture the true color of this bearing. The cage is a beautiful purple, similar to the brightest ring on the wrist pin.
(https://i.postimg.cc/NGNHcxtn/image.jpg)
Plenty of oil down there, and another look at the failed base gasket.
(https://i.postimg.cc/zXv5sCD4/image.jpg)
It was 25-ish years ago...I might have done this, or it might have come to me this way. I would say no harm done, but probably no progress, either.
(https://i.postimg.cc/G2YwLKTn/image.jpg)
As God is my witness, I thought they could fly. I have been telling people for the aforementioned 25-ish years that this engine is just 1st over, and it turns out to be a big-bore! I just happen to have acquired a set of 65.50 pistons from Ken recently.
(https://i.postimg.cc/90SzsVSx/image.jpg)
My son dropped by the garage and said: "Where is your bike?" I pulled the FZR swingarm down from a shelf and began assessing the transplant; it will need to be narrowed at the pivot to fit into the RZ frame, but I need to figure out if this idea will work at all without a massive engineering undertaking. The FZ swinger I have been using is a very straightforward swap, and I hope this arm will go in with a similar effort.
Wade keep moving on the refresh, I am envious of your RZ, I bought a RZ new in 1984 and sold it when my daughter was born. I purchased another RZ three years later from a very good friend who bought it new, and sold to purchase inventory for my bike shop... wish I had another one ... Your efforts will be enjoyed by yourself and others. I look forward to the progress.
Excellent work. Following your progress. If you need any old school glass bead blasting give me a shout, though shipping costs back and forth might be an obstacle.
Thank you Russ, and Tim; yes, it's a fair jaunt from my place to yours! I don't love the cosmetic aspects of this undertaking, but I think I must force myself if I'm going to be happy with the outcome.
looks great. and def dont trust 40+ year old electronics. they will fail you sooner than later. ask the triple folks about it 15 years ago.
Im very curious as to how the fzr arm will go in. when i did mine i have to narrow it AND bore the bearing pockets deeper into the arm to make it fit. make sure you don't have to do that, or plan to do so ahead of time, its an easy one to over look.
The arm will certainly need to be narrowed at the front, and that's about as far as I've gotten with it. I want to feel comfortable that the linkage is going to work out before I do any cutting on that arm. Thanks for the heads-up regarding the bearings, Mark.
