The 2-Stroke Garage => Haus of Projects => Topic started by: RustyRD on December 15, 2019, 10:01:56 AM
Title: RD Monoshock ninja susp. swap
Post by: RustyRD on December 15, 2019, 10:01:56 AM
Hello, new to the forum, however not new to RDs. Here is my project with suspension swap underway.
Title: Re: RD Monoshock ninja susp. swap
Post by: 85RZwade on December 15, 2019, 10:11:36 AM
Looking forward to more about this! Approaching a similar transformation with an RD myself, and although my mono shock design is different , I'm interested to see how you worked it out. Which Ninja is the suspension donor?
Wade
Post by: RustyRD on December 15, 2019, 10:39:34 AM
Wade
The donor bike was a 2004 ninja 250. The swap has been fairly straight forward, and I plan on using a different triple tree. All balls racing was used to source the bearing for the fork swap.
Russ.
Post by: RustyRD on December 28, 2019, 12:52:49 PM
Another view of upper shock mount location.
Post by: RustyRD on December 28, 2019, 03:29:43 PM
Rear swap nearing completion.
Post by: 85RZwade on December 29, 2019, 03:07:58 PM
Nicely done, very sanitary.
Wade
Post by: soonerbillz on December 31, 2019, 02:07:31 PM
Curious as to why you chose the 2004 ninja 250 for parts.  The wheels are 16" and tires are not widely available. A 2008 or newer parts bike offer better suspension which still is functionally/dimensional similar to that of the pre gen ninjette.
Most importantly the rims are 17" which opens up a world of options for you.
I have a 74 RD250 that I am doing a similar but different thing on. I will retain the conventional twin shock layout but use 2009 Ninja 500 fork, 17" rims and brakes. I will modify the 500 swing arm to fit the RD frame and accept the shocks.
Post by: RustyRD on December 31, 2019, 07:40:31 PM
Hello  It was more about the deal. The 04 ninja was free, and the prospect of a budget build flashed through my brain. I have kept in mind if I did not like the swap I would revert back to twin shock. Wheel are 7lbs lighter than the old RDs. both sets of wheels were weighed ready to ride.  Modification on this project will be ongoing. This will be a street bike only, and strictly a hobby. The ultimate goal is having fun.
Post by: m in sc on December 31, 2019, 07:53:35 PM
you can get bt45s in the 16"ninja sizes. well, you could. I think you still can.  :twocents:
Post by: RustyRD on December 31, 2019, 08:02:29 PM
Thanks for the heads up on the tires. Ihave a set of Pirelli MT75 now. I will try these as I shake down the build. Waiting on heads and cylinders to return from Supertune. I like a deal.
Post by: 85RZwade on January 01, 2020, 09:51:45 AM
I can relate to the budget build. I am constantly looking at what I can do with what I already have, much of which came to me free or cheap needing a home.
I had a Nighthawk S with a 16" front BT45 years ago, and it was just fine. Still using BT45s on my RZ...but not often enough!
Wade
Post by: RustyRD on January 01, 2020, 12:47:47 PM
I get lots of satisfaction creating something from items on hand, and obtained free or low cost. Building a bike that handles and hauls the mail cheap is half the fun. I have owned two RZs both were 85 models, and miss both. The first was purchased new, and had FPP pipes and boysen dual stage reeds. I rode with a group that all riders were on liter size bikes and enjoyed them all being amazed at the RZ's performance.
Post by: soonerbillz on January 01, 2020, 01:12:31 PM
I love seeing folks building budget bikes.. and I've used anything and everything in my possession to build up bikes. I like what you are doing..
My comments were strictly to express my experience in the little ninja .
As for your build .. what shock are you using ..if it is the factory ex250 part I can recommend a better path.
A 2006-2007 Suzuki GSXR 600 shock will fit with very little modification.
It beefier, has better adjustability and has a integrated gas reservoir.
I have installed these on many ninja 250's.
They are plentiful on Ebay for cheap too!
Good luck!
Post by: RustyRD on January 01, 2020, 04:10:13 PM
Thanks for the direction on the rear shock, I am a firm believer in applying advise from experienced individuals. Supertune has been the receiver of my build budget dollars at this point. Ignition and carbs are next, then powder coat of the frame. I guess I cant leave out seat and paint.
Post by: Gil Gallad on January 02, 2020, 05:01:19 PM
i used a gsx-r400 shock on my ninja frame. needed a bit of work on the top mount, but nothing too serious, then added a bracket for the remote res. the hard bit was building the cradle for the suzuki gt350 engine - that's a 64mm x 54mm proper 350  :vroom:
cheers, gil.
Post by: RustyRD on January 03, 2020, 07:28:52 PM
Post by: RustyRD on January 03, 2020, 07:31:26 PM
Post by: RustyRD on January 03, 2020, 08:12:26 PM
Gil    So is it a GT380 in a ninja frame? That is proper. Thanks for the info on the rear shock.
Post by: RustyRD on January 04, 2020, 07:49:40 AM
Sorry for the duplicate post, I did not see that an additional page was created.
Post by: Gil Gallad on January 07, 2020, 05:40:55 AM
rusty, no mate, it's a gt350 twin. suzuki didn't build one - not a full sized one - so i built my own. 64mm liners in 250 ramair barrels, standard ts185 pistons, 4mm aluminium base plate, heads machined to my spec and gt250a 28mm carbs. 1989 ninja rolling chassis cost me peanuts, inc documents. built an engine cradle and junked that terrible kawasaki rear shock, fitting the gsx-r400 shock with remote. there's a few pics in the haus of projects section, under gpx/gt half breed  8)
cheers, gil.
Post by: Gil Gallad on January 08, 2020, 04:49:20 PM
how she sits atm. you'll have to look close to find the rear shock and remote, but it's all crammed in there somewhere  ;D don't know whether you can spot it on this photo, but there's a pair of 4mm baseplates fitted - the ts185 pistons were 4mm higher than the gt250 pistons. just waiting on the paintwork and recover the seat  8)
cheers, gil.
how she sits:
(https://i.postimg.cc/KvgdPzM4/howshesits.jpg) (https://postimages.org/)
Post by: pdxjim on January 08, 2020, 06:30:59 PM
Looks fantastic!
Can't wait to see it with the bodywork fitted. :metal:
Post by: 85RZwade on January 08, 2020, 09:46:47 PM
I'll second that, excellent work Gil. That's going to be a very cool bike very soon!
Wade
Post by: RustyRD on January 09, 2020, 03:13:38 PM
Gil   CLEAN.  I really like the way that looks. That should be a fun, quick ride. What year is the donors?
Post by: Gil Gallad on January 10, 2020, 09:05:17 AM
thanks for the thumbs up - appreciate it  ;D
rolling chassis, complete with paperwork, wheels, frame, seat, tank, wiring etc from 1989 and cost me the princely sum of £59 - or about $77 in your money. plus a bottle of jamesons irish for the lad who fetched it for me. all in all i'm pretty pleased with it. apart from the newly rebuilt crank dropped one of the middle crank seals after about half an hour of running, most probably due to this crap petrol we get round here. it literally melted the centre of the seal  :bang: that's gone back to the crank builders for another new one - this time supplied by me, and tested in a pot of petrol for a couple of hours. this time it should last  8)
cheers, gil.
Post by: RustyRD on January 10, 2020, 06:52:23 PM
Gil
What triple tree setup is that in the pic? Will you be using the stock ninja tank and body panels? I hate component failure when you are expecting long life from new parts. :umm:
How different is the GSXR400 shock mounts from the ninja?
Post by: Gil Gallad on January 11, 2020, 08:43:18 AM
everything is gpx250 [apart from the rd headlamp and gt headlamp ears] and yes, i'm using the stock tank etc. the original one was kaput, so i got another - it cost me more than the rolling chassis  :umm: bottom mount is the same and the top mount i needed to cut some away and weld a piece in. about 10 minutes work that was all. think you'll find the gsx-r shock has 10mm holes in it and the gpx has 12mm, so you'll have to drill them out. don't worry, there's plenty of meat on the ends of the shocks. hmm, thinking back i reckon i just drilled one end and changed one of the bushes for a gpx one  8)
cheers, gil.
not a very good photo, but i took part of the ninja top bracket out and put gusset plates in. there's plenty of strength there:
(https://i.postimg.cc/X7Q0Fbpr/gpxshocktop.jpg) (https://postimg.cc/tYZfQ8db)
Post by: RustyRD on January 11, 2020, 09:42:37 PM
Gil
Thanks again for the ideas. Your work looks great. A nice clean sane approach to the build. :clap:
Russ
Post by: RustyRD on January 11, 2020, 10:17:11 PM
Now time to finish the assembly of the engine. Chuck Supertune applied his touch to the cylinders and heads.
Post by: RustyRD on January 11, 2020, 11:01:23 PM
I liked the ninjette kickstand so I removed the OE and transplanted the little ninja stand. Cleared up issues with clearance with Spec2 pipes.
Post by: RustyRD on January 11, 2020, 11:11:11 PM
So to save money on rear sets I looked to the little ninja again, and with a little modification to the frame tabs the ninja rear sets were part of the RD.
Post by: RustyRD on January 11, 2020, 11:17:59 PM
I am really looking forward to the music these jewels can make. Gary Shumake's Spec2 F1 pipes. I have to decide whether to leave natural or paint.
Post by: 85RZwade on January 12, 2020, 12:22:23 AM
Gorgeous.  :drool: One vote for natural finish!
Wade
Post by: RustyRD on January 19, 2020, 06:59:49 PM
Well spent some time working on painting cylinders after Mr. Supertune has performed his magic on them. Paint on the cylinder and head.  :clap:
stage one porting and head machined and squish dialed in. Rz manifolds and yz85 reed cages Team Scream Racing reed spacer with stainless hardware. Vape ignition hopefully will arrive on Monday.
Post by: paul1478 on January 21, 2020, 01:40:14 PM
Quote from: RustyRD on January 11, 2020, 11:17:59 PM
I love them natural. just Mop and glow. only problem is the head pipes get black after a while. just need to wet sand lightly and reapply.
and if you ever spill any gas on them need to reapply or they will start to rust.
Post by: RustyRD on January 21, 2020, 08:19:16 PM
Thanks Paul. I'm afraid if I paint them I will always be reworking the paint on them. My Z1-r had a painted header at one time and I spent too much time repainting them.  I wonder how many different types of products are used on natural finish pipes. I have read of some riders using wd40, and I'm sure countless others. I was thinking just a light machine oil. Any thoughts. On a high note my vape ignition arrived today and I have been able to start offering it up to the engine.   :whoop: :celebrate:
Post by: sav0r on January 21, 2020, 09:07:32 PM
Mop and Glow is surprisingly effective and incredibly easy. You will have to clean them occasionally, but if you keep the mop and glow on them they will survive pretty well.
Oil burns off, then they are unprotected, and rust will take hold.
Post by: RustyRD on January 21, 2020, 09:15:43 PM
Thanks for the input. I hope they see some heat in the near future from the engine running. :clap: Mapping out ignition now.
Post by: pdxjim on January 21, 2020, 09:20:25 PM
+1 for Mop and Glo.
Post by: RustyRD on January 29, 2020, 08:17:08 PM
the engine slowly going back together, and still have more items on the must have list.
Post by: RustyRD on February 02, 2020, 06:47:52 PM
Well, took the time today to assemble the top end. Getting closer to installing the engine in the frame for some final fitting. Then frame goes to powder coat and finish triple tree swap.
Post by: RustyRD on February 04, 2020, 08:30:07 PM
Daryl
Thanks for the kind words. The rear sets can be mounted to the passenger peg position with a modification to the stock rd mount location. I will attach some before and after pics. The stock passenger mounting location was cut with a cutoff wheel and a die grinder in the center of the two bolt hole locations. I then ground the welds along the bracket and frame tube to allow me to reposition the remainder of the mount tab. I placed a bolt through the rear set retaining the removed tab, and then bolted to the tab still attached to the frame then tacked in place and finish weld. I am more than happy to send additional pics if you need. The stock shift linkage will be to long as is. I will either modify the kawi unit of fab up a new linkage. My first impression is the stock piece can be made to fit by cutting to correct length and cutting new threads. The shifter shaft ninja portion fits shifter shaft of RD. I am happy to send more pics to help if needed.
Russ
Post by: RustyRD on February 04, 2020, 09:35:58 PM
The task are getting smaller, and now its time for clutch basket refurb. New dampers and tap bosses for bolts and install clutch.
Post by: 85RZwade on February 05, 2020, 01:23:18 AM
Good on ya, Russ! You are making nice stuff and great progress.
Wade
Post by: RustyRD on February 10, 2020, 09:04:44 PM
well tank mounts are complete, and front fender came in today. I am still on the fence about front fender. However it fits the 16" diameter wheel. Oh well at least progress is being made. Performed pressure test on engine with a 1.25 psi drop over a ten minute period with a starting pressure of 6.5 psi. :clap: thank you SUPERTUNE.  Here is my pressure test rig.
Post by: m in sc on February 12, 2020, 10:14:57 AM
id strongly recommend a 17" ex500 wheel.
motor looks great.  :clap:
Post by: RustyRD on February 12, 2020, 06:52:52 PM
Thanks for the suggestion, when I get to the point of the bike being motivated under it's own power I can really start to evaluate the wheels and suspension further. I hope the rear monoshock conversion is what I am expecting. If I am pleased with initial results then wheel swap and further suspension upgrades will follow. Thanks for the kind words on the engine. I am so anxious to see all of it in one piece. :whoop: :whoop:
Post by: m in sc on February 12, 2020, 08:50:56 PM
I understand, but trust me on this. friend did a swap with the 16 and it was like riding a shopping cart with a wobbly wheel, super sketch at speed, even with a steering damper. you'll be happy with the rear and suspension (even though the arms a mile long)  and brakes & forks in the front though. not being critical, just experience.  :twocents:
Post by: RustyRD on February 13, 2020, 05:43:47 AM
Thanks, I sure hope it works out.I did not feel like like you were coming across as critical. I will start doing my wheel search soon. Tire selection is much better with the 17" size. I am curious if there is a difference between the 500 and 250 ninja 17" wheels other than spacer width and style. That means more research on my part.  this us a 30 year update to the suspension and there are bound to be pitfalls. When I have this little RD under its own power the wheel swap will be a difference I can relate to someone else. That is if I don't swap wheels before I ever do a test ride on the current wheels first. I am really starting to get excited about it making to this stage of completion, however it will never really be completed. :vroom: :vroom:
Thanks
Russ
Post by: Kawtriplefreak on February 13, 2020, 08:32:37 AM
If memory serves the 250 and 500 EX wheels are the same. Not sure on the forks and spacers. You will like the 17 better.
Post by: RustyRD on February 13, 2020, 07:26:43 PM
I have a question for the forum, I plan on running TM32 carbs. Anybody running them and what is your findings? engine- Chuck supertune stg 1 porting, 400 head gasket conversion combustion chamber reworked by supertune, yz85 reed cages and rz350 manifolds, bore 65.25mm, SpecII F1 pipes, vape ignition.
Post by: pscook on February 19, 2020, 09:16:10 PM
EX250 and 500 wheels are different, both ends. I swapped from 16" to 17" on my EX250 race bike and the front was a pain as you have to relocate the caliper as the rotors are different diameter and the speedo drive is on the wrong side (rules mandated OEM model forks and swingarm). The rear is very close, but you need to modify the brake caliper bracket and torque arm. A fellow on the WERA boards used to sell the rear caliper bracket modified, I'll see if I can find him for the info. As for the front it's much easier to swap in the entire EX500 front end. I believe that the stem is the same between 250 and 500, so you can just put the entire set up on there. The forks might be longer, but as I never dealt with that end of it I can't say for sure. But I know for a fact that the front wheels and rotors are different.
Post by: RustyRD on February 20, 2020, 05:55:48 AM
Thanks
I need to check, if maybe the bolt pattern for the rotors are the same. Possibly just retain the smaller rotor :umm: but still have speedo drive :umm: Sometimes it the trip, rather than the destination :vroom: oh well I am having fun, I think.LOL :whoop: :whoop:
Post by: RustyRD on February 21, 2020, 07:35:13 PM
Nearly as good as it gets, new parts showing up on your doorstep :celebrate: Ok so i made the commitment to go with TM32 Mikuni. Look forward to getting the jetting correct.
Post by: Czakky on February 21, 2020, 08:45:44 PM
That's what I've got mixing fuel in mine. Also waiting to get jetting sorted.
Post by: RustyRD on February 21, 2020, 09:24:18 PM
I will be running premix also, have had some positive input from Chuck that has made me feel good about choosing the TM32. Still more to do before engine goes into frame. The frame still has to have to go to powder coat, and the seat choice has to be made.
Post by: RustyRD on February 23, 2020, 12:48:33 PM
OK, so I have been trying to figure out the seat, and have been looking at another old part lying around and looking for a use for it. Being a pack rat is a disease :whistle: maybe... Anyhow I kinda like the way this looks. Cowl off a 78 kz1000 if memory serves me correctly. constructing the seat for this combo will present the next challenge.
Post by: Czakky on February 23, 2020, 12:53:30 PM
That works for sure. :patriot:
Post by: RustyRD on February 23, 2020, 01:35:17 PM
Thanks for the input, still keeps the old school street bike look.
Post by: 85RZwade on February 23, 2020, 08:42:03 PM
Oh, hell yeah, that looks good to me
Post by: RustyRD on February 23, 2020, 08:46:37 PM
I found the tail section on a shelf under one of my work benches, and after I placed it on the frame I kinda felt the same way.
Thanks
Post by: 85RZwade on February 23, 2020, 08:51:26 PM
I think you had better clean out the garage and see what other treasures you've forgotten!
Post by: RustyRD on February 23, 2020, 09:15:03 PM
LOL   so right. I have had that kz tail piece since about 1999. Have an engine for it in there somewhere.
Post by: 85RZwade on February 23, 2020, 11:23:11 PM
Sounds like your next build will be under "4-stroke blasphemy"
Post by: RustyRD on February 24, 2020, 06:23:11 AM
 :whistle: I am a huge fan of two wheels and a engine :vroom: some more than others, the RD has been in my possession  for almost 40 years. The Z1-r I bought new with the help of my father.
Post by: 85RZwade on February 24, 2020, 08:30:40 AM
Two fine Kawis! A friend has his Z1-R in pieces, and I've been trying for years to convince him to put it together...or sell it to me! I have an '82 1000LTD that came to me as an orphan a few years ago that will need a pretty full restoration. It would be cool to have a big air-cooled four at my disposal, but it's not at the top of the priority list yet.
Post by: pscook on February 24, 2020, 10:04:05 AM
Quote from: RustyRD on February 20, 2020, 05:55:48 AM
Thanks
Front rotors are not the same bolt pattern. I tried. The front wheels are completely different while the rear are the same (except diameter). It's not hard to bolt the wheel in, but it requires some math to get the caliper to mount and align the 500 wheel and 250 fork.
Post by: SUPERTUNE on February 24, 2020, 10:23:39 AM
Quote from: RustyRD on February 23, 2020, 12:48:33 PM
Looks like a perfect fit to me!!
With you using the 400 tank, get my modified Raptor fuel petcock to feed those TM's!
C
Post by: RustyRD on February 24, 2020, 06:48:06 PM
does the year model on the Raptor come into play? Thanks for the info on the wheels  ;D
Post by: RustyRD on February 28, 2020, 02:14:31 PM
ok carbs in place now the vent hoses, maybe I can braid them, or dreadlock ....naw ... something else. Half the fun of building is routing and making it look clean. One more step closer. :vroom: :celebrate:
Post by: SUPERTUNE on February 28, 2020, 09:31:34 PM
Quote from: RustyRD on February 28, 2020, 02:14:31 PM
Take them off and throw them away... nothing but a pain in the butt...It's not a motocross bike!
C
Post by: RustyRD on February 28, 2020, 11:44:27 PM
Your killing me :whistle: cmon you know your up for a challenge
Send filters
Russ
Post by: m in sc on March 01, 2020, 08:29:59 PM
i used a piece of tig filler rod, bent it, and made a loop for them to pass through that mounted to the bowl screws. completely unnecessary but tidy.
(http://www.2strokeworld.net/wp-content/uploads/LC-HYBRID/vm34-large-bellmouth-18/lc-new34s_08_zpsngzvywqa.jpg)
Post by: RustyRD on March 01, 2020, 08:42:16 PM
Clean...I like the setup :clap: :clap: Thanks for pic
Post by: 85RZwade on March 01, 2020, 08:49:16 PM
Yes, that's a nice solution
Post by: RustyRD on March 20, 2020, 10:46:19 PM
Well had some time to work on THE Project, and just don't have enough time to spend on it like I would really like to. oh well gotta eat and pay the bills. The engine is almost ready to button up. I need to map out any other mounting brackets or tabs then pull engine , and disassemble and have frame powder coated.
Post by: 85RZwade on March 21, 2020, 02:47:40 AM
That engine looks right at home in there!
Post by: RustyRD on March 31, 2020, 07:50:13 PM
well spent some time trying to map out exhaust mounting. I have installed chain and sprockets, and still making sure I have all tabs and cutting done before powder coating. Seat and tail section will be the next task.
Post by: RDFL on April 01, 2020, 04:16:30 PM
What's the wheelbase?
Post by: RustyRD on April 01, 2020, 07:32:59 PM
wheelbase  is at 57 1/2"  Easy Rider, waiting to see how it rides, and getting closer to first fire up of engine then followed by test ride.
Post by: RustyRD on April 05, 2020, 09:07:16 PM
well trying my hand at creating a seat from scratch. Frankenseat I hope the end product looks and feels good, if not I might go tracker tail section. The great thing about a hobby like this, if you dont like the way it looks you have something to spend some more time and money on it.
Post by: 95bravo on April 07, 2020, 05:50:31 PM
You gotta start somewhere - and at least you have a start.  My rd existed w/o a seat for two years - but I still enjoyed riding it!  :righteous:  You're right about the hobby angle -- it is a continuous journey!
Post by: RustyRD on April 10, 2020, 10:09:49 PM
Frame is back from powder coat. This stuff is hard as a rock. Same day, drop off in the morning pick up at lunch  :whoop:
Post by: RustyRD on April 12, 2020, 09:07:45 PM
well frankenseat is taking shape, I am hoping it does not make people run and scream :eek: At least it is forward progress. Wiring, lights and final check of timing and one more leak check with newer manifolds just to be safe before first fire up of engine.
Post by: 85RZwade on April 13, 2020, 01:06:15 AM
Your seat looks like it turned out well. Interested to see how the addition of headlight, pipes and side panels (?) will affect the proportions of the bike.  :bacon:
Post by: RustyRD on April 13, 2020, 09:53:33 AM
Thanks, I have been searching for headlight brackets that appeal to me. Search has been all over the place. It seems there is plenty either hi dollar or cheap.
Post by: 50gary on April 13, 2020, 10:07:20 AM
For headlight brackets (I've done this 3 X) I ebay a matching (to the forks, that way you know they'll fit) top triple clamp and cut the center section out and that leaves the two pinch clamps.  Then I make the two arms (aluminum) to hold the headlight bucket and TIG weld them.  You can make them as plain or fancy as you want.
  Cheers, 50gary
Post by: RustyRD on April 13, 2020, 03:34:39 PM
Thanks Gary  I will start a search today.  Still wrestling with what handlebar switches I want to use
Post by: RustyRD on April 19, 2020, 05:30:43 PM
Another use for discarded clutch hub rivets and an old and cheap tire lever
Post by: RDFL on April 19, 2020, 06:45:22 PM
Great tool, I make a lot of my specialty tools too.
Post by: RustyRD on April 19, 2020, 07:58:29 PM
Thanks, you know half the time you make a tool its to save time
Post by: RustyRD on April 25, 2020, 06:29:06 PM
one more step down, and countless more to go. Brackets arrived to mount headlight so I had no choice but to mount them.
Post by: RustyRD on May 05, 2020, 08:58:19 PM
well have the shift linkage ready for the first test ride, and hope there is not anything major I have overlooked.
Post by: 85RZwade on May 06, 2020, 01:07:48 AM
That's a winner, Russ. Looking forward to the first ride report!
Post by: RustyRD on May 06, 2020, 07:33:52 PM
Wade here ya go. First ride in my neighborhood, distance one mile. No parts fell off :clap: carbs are way rich, however the engine pulled hard off idle with a noticeable strong hit around 2/3 throttle and blubbering after that. The quick run was really just to check for odd noises and abnormal operation. so far so good. Waiting on jets to arrive and setup carb a little closer per Mr Supertunes suggestions. It has been since 1986 since I had my RZ350 and I sure missed the cackle and burble of a hot two stroke. :vroom:
Post by: 85RZwade on May 07, 2020, 12:57:06 AM
Right on, Russ! It feels good, doesn't it? Play with brass a little and you'll soon be hearing that sweet 9,000 rpm song. My RZ is almost ready to start riding to work, and I am so looking forward to the on-ramp :righteous:
Post by: RustyRD on May 07, 2020, 06:12:17 AM
Wade,  you are so right , it is very satisfying when making wholesale mods to an engine, and getting to run at full song.  :whoop: This bike was at my fathers house in a shed, and when  I discovered all the parts I had truly forgotten about, this became a project that started last year. I truly miss my RZ and may likely buy another when the stars align and I don't have to take out a second mortgage to buy it. LOL I sold my RZ I bought new due to the birth of my daughter... ya know priorities. :eek: Gotta love it.
Post by: 85RZwade on May 07, 2020, 08:30:58 AM
I hear ya, boss. I have 4 priorities of my own here!
Post by: RustyRD on May 07, 2020, 06:58:54 PM
we do what we have to do :umm: :whoop: :whoop:
Post by: RustyRD on May 13, 2020, 08:40:14 PM
Alright , received new parts today for the shift linkage. The shift knuckle is a little longer which gives the shifter a little better feel, and is easier on the eyes.
Post by: 85RZwade on May 14, 2020, 01:05:01 AM
Where didja get that sano little item?
Post by: RustyRD on May 14, 2020, 06:13:21 AM
Like it do ya? I took a gamble and ordered this from woodcraft, the little ninja piece fit, however this has an increase in length which improved the shift feel. The part was listed under rearset replacement parts. Here is the part # 05-K128 shift knuckle assembly,female LH, Kaw 650R 06-08. The rod end is left hand threading.
Post by: m in sc on May 14, 2020, 10:54:28 AM
thats a nice tidbit of info. *noted
looks good.  :metal: :toot:
Post by: NoRiders on May 15, 2020, 11:12:42 AM
Excellent work rusty.....  :clap:
Post by: RustyRD on May 28, 2020, 08:30:12 PM
well it was time to tackle the mundane job of installing tires. I installed the pirelli on the front, and nothing like 87% humidity and 85° to make me realize that changing tires is low on my list of things to do. Front today and tackle the rear tomorrow. I decided I wanted to change the top triple clamp, wanted a conventional riser setup to allow the ability to swap between different rise and pull back. Waiting on a koso meter to arrive, and hope it comes in tomorrow, and I can work out placement of the gauge.
Post by: RustyRD on May 29, 2020, 01:46:07 PM
OK, top triple clamp modified, removed the ninja handlebars and cleaned up the casting. Removed the key switch to allow room for new koso meter. Drilled for the risers, and then bead blasted the whole thing. installed an old drag bar that was lying around. The current setup feels really good, however I wonder if a bar like maybe the super bike style h-bar may be even more comfortable. Now I don't like the look of the front brake master cylinder. I hate it when that happens. Well the benefit of this mod is it will allow me to swap bars to suit my preference. Now should I powder coat gloss black of polish?
Post by: RustyRD on May 31, 2020, 07:42:39 PM
 well I have confirmed to myself, I don't like changing tires. The things we do to save money :umm: Discovered another shift knuckle that fits our RDs. This is off a 02 honda vtr 1000
Post by: RustyRD on May 31, 2020, 09:19:07 PM
This is the VTR 1000 shift knuckle on the splines of the shifter shaft. Clean piece.
Post by: RustyRD on June 04, 2020, 09:02:02 PM
another good day for part arrival at home. UPS man is on a  first name basis with me, anyhow new handlebar and switch arrived along with the koso meter.
Post by: RustyRD on June 05, 2020, 04:39:04 AM
ok mounted the meter, I like the position of the supplied bracket positioning, but I feel like I want to locate it between the headlight and upper triple clamp to fill a gap.
Post by: NoRiders on June 06, 2020, 07:10:02 AM
Some solid progress, well done.
That speedo/info centre console looks a bit perched and vulnerable tbh.....I agree with you, tucked in front of the yokes, with the screen no higher than the bars, maybe a bit lower would look much slicker I reckon.
I too avoid home tyre changes.....paid too much for the wheels to be powedercoats just for me to scratch/chip them.....especially when the cost to repair outstrips the coast of having tyres fitted by the local shop!
Post by: m in sc on June 06, 2020, 07:17:38 AM
agreed, drop it down in front of the tree. easier to see there as well.  looks good, dig the wide bars.  :cheerleader:
Post by: RustyRD on June 06, 2020, 07:25:13 AM
Thanks guys, :clap:you have help with the decision. next stop down and in front of the triple tree.
Post by: m in sc on June 06, 2020, 07:56:48 AM
side note, angle it up and back some so as not to be blinded by a reflection (glare) in bright sunlight while riding. :twocents:
Post by: RustyRD on June 06, 2020, 08:20:26 AM
good thinking, I nee to fab up a simple aluminum bracket. I have left some of the  material that was used for the old switch mount just in case, glad I did now. I want to try an experiment with this tiny SLA battery. I feel like with the minimal amount of current draw this should do the trick. 1.4 lbs and small package it is meeting the criteria now. We shall see  :vroom:
Post by: NoRiders on June 06, 2020, 09:01:50 AM
Kickstart only, so long as it can handle the draw of headlight main beam, indicators and brake light on it'll be fine.
Post by: RustyRD on June 06, 2020, 06:22:17 PM
ok some voted for a different location than the supplied bracket allowed so I  whipped up a bracket to relocate the koso meter. Here are some before location and what will likely be its new position. Still need to do final finish on the bracket, however the basic mount is complete.
Post by: m in sc on June 06, 2020, 06:45:42 PM
 :clap: looks nice
Post by: RustyRD on June 06, 2020, 06:55:35 PM
Thanks, it fills the area between the headlight and triple tree looks more complete. need to complete the finish work on the bracket, now polish or satin or powder coat.
Post by: m in sc on June 06, 2020, 07:05:49 PM
its very clean.
IMHO, id counter sink the holes use some countersink bolts. just give it that extra   :bacon:
Post by: 85RZwade on June 06, 2020, 07:06:55 PM
 :agree: looks better there and nicely crafted
Post by: RustyRD on June 06, 2020, 08:12:00 PM
Thank you sir. It is a good feeling when it works out, and looks good. :vroom:
Post by: RustyRD on June 06, 2020, 09:58:16 PM
well good to know that it actually powers up. Now is the time to tackle the wiring for the rest of the bike.
Post by: RustyRD on June 08, 2020, 03:49:10 PM
Mark this countersink is for you, actually I had planned on using button head stainless, and after the suggestion of countersinking the hardware I agreed. I used stainless screws and it is a much cleaner setup.
Post by: m in sc on June 08, 2020, 04:03:05 PM
nice!
in my experience, they dont come loose as easy either as the taper wedges them in a bit.  :toot:
Post by: RustyRD on June 08, 2020, 06:04:55 PM
The small phillips are threaded into the plastic of the meter so have to be careful about the amount of torque on them, but the factory supplied vibration isolator on the meter has been retained.
Post by: RustyRD on June 08, 2020, 08:42:40 PM
Post office was good to me today and brought me more parts. I now have new front brake hose, and  I am really feeling like I want to replace the master cylinder now.  I hate when I run out of time to do things, but 5 am gets here quick.  The question is, retro or modern with remote reservoir?
Post by: 85RZwade on June 08, 2020, 11:10:48 PM
Remote reservoir!
Post by: RustyRD on June 12, 2020, 08:16:48 PM
I managed to have enough time to install front brake hose, and it even helps the old master cylinder look a little better. well the hunt for handle bar switches continues. Any suggestions out there? (for switches) I tried a left side kill/ turn/ hi low K&S switch but quality was low.
Post by: m in sc on June 14, 2020, 05:37:48 PM
https://www.ebay.com/itm/CNC-Switch-Motorcycle-Handlebar-Button-Latch-Front-Momentary-Cafe-Racer-Custom/173425534625
Post by: RustyRD on June 14, 2020, 08:06:40 PM
Mark Thanks for the link, hate that it is shipping from china, maybe there is one to be had in North America.  Anyone ever use Motogadget?
Post by: m in sc on June 14, 2020, 08:57:44 PM
yeah, there is that. i cant say as ive ordered one, but thats saved in my watch list from like a year ago.  motogadget is nice stuff.
Post by: RustyRD on June 14, 2020, 09:28:28 PM
I have been eyeing the motogadget m unit. Watched a video on it , and I like the system.  It all looks well made.
Post by: RustyRD on June 23, 2020, 07:02:18 AM
Time to tackle wiring, and after some research I decided to go with Rowe PDM 60. I started to use a fuse block that I have on hand, but I like the idea of being able to adjust current to the circuit and breaker that can be reset. I hope to have it to work with this weekend :clap:
Post by: NoRiders on June 23, 2020, 02:06:41 PM
Dash is much better, nice one.
Switches: I found a Honda Dominator kill/run & start switch which is slim and reasonably unobtrusive and being Honda, good quality too.
See it here
(https://i.imgur.com/FOaBl0o.jpg)
quite slim at 30mm and just red buttons. The loom also carries the front brakelight switch feed, including two spade connectors.
Post by: RustyRD on June 24, 2020, 05:13:58 PM
I agree quality should be there. I have a VTR1000 and the switches on it would be great, however one switch is no longer available from Honda. Thanks for the tip.
Post by: RustyRD on June 26, 2020, 06:49:29 AM
Got lucky and PDM60 arrived and I have items on hand to wire the RD. I still need to configure the battery and distribution module platform. Step after step it nears completion,and the next big item will be paint for the tank and other body parts.
Post by: RustyRD on July 03, 2020, 06:51:21 PM
Took time to get some aluminum and start working on an electrical tray. There always seems to be more space in the planning phase, compared to the actual layout of components. working to get inner fender and tray to be functional and clean.
Post by: RustyRD on September 01, 2020, 07:01:10 PM
 Shopping for a decent electrical connector kit, any recommendations out there?
Post by: rodneya on September 02, 2020, 01:00:10 AM
Quote from: RustyRD on September 01, 2020, 07:01:10 PM
Depends what type you are looking for, but vintageconnections has good stuff
Post by: RustyRD on September 02, 2020, 06:20:07 AM
Quote from: rodneya on September 02, 2020, 01:00:10 AM
Thank you  sir, I will check them out.
Post by: pidjones on September 02, 2020, 08:10:59 AM
VC is my go-to site for refurbing old GoldWing electricals. Great folks to work with, too. They can custom-make things if asked.
Post by: RustyRD on September 02, 2020, 06:48:15 PM
Quote from: pidjones on September 02, 2020, 08:10:59 AM
That's great to hear, I looked at the site just last night, and good to hear positive comments about them.
Thanks
Post by: RustyRD on September 07, 2020, 07:34:10 PM
I finally received the connectors and crimping tool. I was able to get the kit from Economy, and use our discount. Crimper works like a champ.
Post by: RustyRD on September 13, 2020, 07:58:04 PM
Well have had some time to work on my RD, and mapping out the wiring and battery location.
Post by: paul1478 on September 14, 2020, 07:19:32 AM
the photos of your bike really look good. but in person, wow! you are going to have a NICE bike when you get done. I will have to go back down for BBQ and riding when you get it done.
Post by: RustyRD on September 19, 2020, 08:30:59 AM
Thank you , sounds like a plan. I will update as to when it is road worthy.
Post by: RustyRD on September 22, 2020, 08:24:15 PM
Ok, I thought since I am trying to get away with a small battery might as well try to lighten the electrical load by trying a LED conversion bulb. Current draw of the halogen H4 was 2.6 Amps at low beam and 5.1 Amps on high, the LED comes in at 1.8 Amps on low and 2.1 Amps on high. I just wonder about durability? 35 $ so not a huge loss if it pukes out.
Post by: RustyRD on October 11, 2020, 11:57:53 AM
I received the switch I ordered for ignition, made an aluminum bracket to mount it. Tried to keep it in an inconspicuous location. It is the small things that seem to take so long. :eek:
Post by: m in sc on October 13, 2020, 07:30:53 AM
 :clap: looking good.
Post by: RustyRD on October 15, 2020, 10:39:23 PM
Thank you , you know all these little task start to take a lot more time than I planned on. :umm: :umm:  getting there little by little.
Post by: 85RZwade on October 19, 2020, 10:21:26 AM
You'll be happy later on with the attention you're giving to the details now  :thumbs:
Post by: RustyRD on October 19, 2020, 07:02:32 PM
Thanks for the encouragement, made a little shield to cover the switch housing, and the vintage connections kit and crimper tool are awesome. Here is a before and after on the switch.
Post by: RustyRD on November 07, 2020, 08:00:03 PM
Spent a little time today in the shop with the RD, life has been throwing some serious darts around lately, and slowing my project down. I know I am not alone in this battle. Wiring is starting to progress and I was curious what the bike was weighing in at, 258lbs. tank, seat side panels not in place, however I like the results so far. Still have more to do on wiring, little at a time.
Post by: RustyRD on November 11, 2020, 07:42:21 PM
OK I have wiring near completion, with engine running charging system putting out 13.8 volts. Great to  hear engine run again, after starting the wiring process it has been several months since last run. :clap:
Post by: m in sc on November 12, 2020, 10:31:34 AM
nice! well done
Post by: RustyRD on November 22, 2020, 05:03:07 PM
The RD project snuck out of the shed today, still lots of details to work out, but moving forward.
Post by: RustyRD on December 07, 2020, 08:26:34 PM
I decided to setup cable actuated choke and ordered cable conversion choke and twin cable. The USPS is all over the place with there service, ordered both at the same time from different locations the 24 of November. One was shipped from MO. one from WI. four days on one, and thirteen days on the other :bang: :umm: Go figure. Tracking number supplied by both, oh well. I have parts in hand and now I have to go out and do the deed. I need to create a mount bracket for the lever, but should not be to tricky. Famous last words. :whistle:
Post by: m in sc on December 08, 2020, 10:33:30 AM
nice!  :clap:
Post by: RustyRD on December 08, 2020, 12:30:58 PM
Running the TM32's, setting the choke on the right side carb is a little bit of a p.i.t.a. :vroom:
Post by: m in sc on December 08, 2020, 01:15:28 PM
preaching to the choir, thats why i did the exact same thing.  :toot:
Post by: RustyRD on December 08, 2020, 01:34:47 PM
woohoo :vroom:
Post by: Czakky on December 09, 2020, 11:18:53 AM
Quote from: RustyRD on December 08, 2020, 12:30:58 PM
I've got the same carbs. I'm thinking I should do the same...
Post by: pdxjim on December 09, 2020, 01:07:11 PM
Quote from: RustyRD on December 07, 2020, 08:26:34 PM
Got a part number or link please?
I'm usually pretty good at sniffing this stuff out, but in this case can only find the single cable ones.
Post by: RustyRD on December 09, 2020, 05:00:22 PM
Sure do.
Parts Unlimited Universal Choke Cable - Mikuni Dual Carbs #928
Cable choke conversion MK-412.
Hope this helps. I have not installed yet, however plan to this afternoon after work.
Post by: RustyRD on December 11, 2020, 07:11:29 PM
I had the chance to go out and work  on the RD, I wanted to install the cable choke conversion. Nearly perfect weather today sunny and 67° so I needed to provide a mount position for the lever. The position I chose offered up the least resistance. :whistle: I will see how I like this position for now, and if I don't like it I will make up a cable and relocate.
Post by: m in sc on December 12, 2020, 07:50:07 AM
nice  :clap:
Post by: pidjones on December 12, 2020, 08:00:32 AM
Ship it!
Post by: RustyRD on December 12, 2020, 09:24:59 AM
Thank you guys, I was hoping it would not make folks turn n grimace. ;D
Post by: RustyRD on December 12, 2020, 06:54:38 PM
Well I decided to make a bracket for the tail light . The devil is in the details, and all the small jobs are mounting up in hours spent. This is a KZ1000 tail light and tail section, next task will be to mount side panels.
Post by: RustyRD on December 20, 2020, 05:14:32 PM
Received another part today, pressure switch for rear brake light, just did not want to run a mechanical switch, so on goes this one. Now if the post office will bring my new tail light :eek:
Post by: m in sc on December 21, 2020, 02:25:45 PM
ive used those a lot, i like em.
dig the tailight brace arm.
Post by: RustyRD on December 21, 2020, 02:44:23 PM
Thank you sir, I tell you what, the small jobs take as much if not more time than doing major task. Top end, crank , tires. Oh well I guess that why I have been working on these things since I was a child. My first real motorcycle was a Yamaha Jt1 mini enduro 60.  :whoop: :whoop:
Post by: RustyRD on December 31, 2020, 11:07:33 AM
I felt like Charlie Brown waiting on this to arrive, good grief. Three weeks USPS must truly be swamped, anyhow I have a new tail light to install on my project now. A nice new years eve afternoon job. Took some time out of the Holiday schedule to install new tail light and run wiring for it.
Post by: RustyRD on January 14, 2021, 08:50:36 PM
Spent some time on the project, connected the KOSO meter and tach reading high. After referring to meter instructions the most probable cause is non resistor plugs or caps. Vape ignition specs call out no more than 5k ohms for plugs and cap combined. I have a large supply of plugs so I researched NGK for cap info, and discovered not only different resistor values also stud or nut terminal on plug. :umm: So I guess my point is ya learn something new all the time. I am sure many of you are aware, however the source is a very good starting place.
Post by: m in sc on January 14, 2021, 11:03:13 PM
i had all sorts of issues with a speedometer and tach setup on mine, triggered it off one of the alternator leads and set ti to 12? cyl i think when i had a vapor, and that seemed to help. finally ditched that went to an spa.
Post by: RustyRD on January 15, 2021, 04:53:41 AM
I hope I will not have to ditch it, however it is a constant work in progress. Thank you for the additional info.
Post by: pidjones on January 15, 2021, 08:41:05 AM
Many of the NGK resistor caps have removable resistors. If only resistor plugs are available, you can always replace the resistor with a short piece of copper wire (~#10 solid should fit).
Post by: m in sc on January 15, 2021, 10:41:49 AM
usually the resistors wont help much on the vapor units. trust me, been there. triples are even worse. what i -have- found that works well , or at least better, is ferrite chokes on the vapor lines and lines to the coils, and RF drains. as far as an rf drain, i have literally wrapped the wire in aluminum tape and grounded it to the frame on the speedometer/tach units.   :twocents:
some people report no issues. ?
Post by: RustyRD on January 15, 2021, 10:51:01 AM
The koso meter has a ground that is part of the tach signal wire that I have not grounded yet.  Could be a factor. Thanks for the additional input.
Post by: m in sc on January 15, 2021, 11:53:19 AM
yeah, thats probably a BIG part of it.
Post by: RustyRD on January 21, 2021, 04:16:08 PM
I need to stay focused, these jewels caught my eye and I could not resist, and besides they are not stock :whistle: I included a before and after pics on the bike, they still need loctite and grease but I could not deny myself seeing them on the bike.
Post by: RustyRD on February 03, 2021, 09:38:01 PM
well I sure was lucky to score a pair of heads from Lyn, tickled to death to be able to pay him a visit and collect these from him 8)
Post by: RustyRD on February 07, 2021, 02:55:23 AM
  Engine running after rebuild, SuperTune  top end and Lyn Garland crankshaft.
Post by: 350GUY on February 09, 2021, 07:58:49 PM
Russ:
Your bike sounds AMAZING! Like music to the ears! You can tell that the engine is well tuned to spec!
Guys, you have to turn up the volume if you have a good set of speakers! Really cool!
K'rgds,
Daryl
Post by: RustyRD on February 12, 2021, 06:38:55 AM
Thanks Daryl
new needle jets arrived earlier this week, had a chance to install along with a modified petcock from a Raptor on the gas tank. Weather has been sloppy here, so no chance to get out and ride it to evaluate the changes  :rolleyes:
Post by: NoRiders on February 12, 2021, 07:14:29 AM
Awesome sounds on tick over...hoping for similar on mine.
The rearsets are cool...liking the exhaust mount....can you post a clearer image please. What's it off of or from?
Post by: RustyRD on February 12, 2021, 07:18:01 PM
Sure, hope this captures the angle you were asking for. The rear sets are from a 02 ninja250, had to modify the stock frame mounts, but I have been pleased with the results. I captured right and left side exhaust mounts. I still need to provide some isolation for the mounts, but the basic mount has been constructed. I used a 10mm, 8mm open ended combo wrench for the mount bracket. Something to get people to ask what it is. Thanks
Post by: m in sc on February 17, 2021, 03:02:33 PM
nice sorting on the rearsets.  :science:
Post by: RustyRD on February 17, 2021, 06:37:23 PM
Thank you sir. :vroom: Those worked out well and added to the uniqueness of the project. Its fun having something just a little bit different than stock to get folks to ask some questions.
Post by: RustyRD on February 21, 2021, 08:53:03 PM
I found an additional image of the rear set frame mod, and little ninja rear set install.
Post by: RustyRD on February 26, 2021, 08:31:15 PM
I found a mirror combo that looks as though it may work ok. Just arrived and will try to install and evaluate them. Hopefully the will be worth money spent. Time will tell, or they may show up on sell your stash :rolleyes:
Post by: m in sc on March 01, 2021, 01:18:06 PM
looks really good. does the kicker clear the RH peg? if not, i might have a solution.
Post by: RustyRD on March 01, 2021, 02:58:47 PM
It does, the peg folds up, and there is ample room for the kicker. One of the things I really like about the way the swap worked out. The kickstarter was also one that was for rear sets
Post by: RustyRD on April 17, 2021, 08:56:42 PM
well I complained about moving because I have not been able to work on my RD. Almost three months without laying a wrench on it. Don't want to make the wife mad, anyway I will have a better spot to work on my projects. I will be upgrading to a shop instead of two sheds, not sure how I want to arrange things yet, however that will be a task in itself.
Post by: SoCal250 on April 20, 2021, 11:32:47 PM
That looks like it should do the trick! :righteous: Look at all that space to be filled.
Congrats
Post by: RDFL on April 21, 2021, 12:22:31 AM
Quote from: SoCal250 on April 20, 2021, 11:32:47 PM
Congrats
And quickly will.
Post by: RustyRD on April 21, 2021, 05:34:15 AM
Thats the sad part, quickly it will fill. :rolleyes:
Post by: RustyRD on May 23, 2021, 09:16:10 PM
Well the light at the end of the tunnel has been turned back on, I am in the process of moving and prepping my old house to sell. A couple of the motorcycles have found their way over to the new shop. There is still a lot of work to do, however moving the RD over has helped to calm the nerves.
Post by: RustyRD on June 27, 2021, 10:41:43 PM
Quote from: RDFL on April 21, 2021, 12:22:31 AM
Congrats
And quickly will.
Well the RD has new room mates. Some riff raff but it makes for a lively group.
Post by: m in sc on June 30, 2021, 04:42:20 PM
nice. always have a push button bike when its time to just GTFO.   :righteous:
Post by: RustyRD on June 30, 2021, 05:12:28 PM
I concur, sometimes your pushed for time and just need a quick fix :vroom: After the dust settles from the move, I want to complete some projects inside my new shop such as lighting.
Post by: RustyRD on July 06, 2021, 09:06:04 PM
Congrats
And quickly will.
I guess I left the door open  :whistle: The space has had to hold some overflow from moving. After the dust settles I hope to resume my RD project.
Post by: m in sc on July 07, 2021, 11:04:25 AM
got a bit of a kz fettish huh?  :whistle: :toot:
Post by: RustyRD on July 07, 2021, 09:57:12 PM
Uhm well I guess I've been found out, there is another Z1-R basket case and a 79 kz1000.  They all want some attention , I am looking forward to being able to spending some time in the shop with them all. Waiting to close on my previous house and then it's game on. Hopefully :whoop:
Post by: RustyRD on August 24, 2021, 09:49:22 PM
Alright it's almost time for paint. Not in love with a color yet. What say you?
Post by: RustyRD on August 24, 2021, 09:54:51 PM
Dr. tells me I need to loose weight to improve my cholesterol , that's only a good thing right?  Less weight on the bike equals quicker acceleration right?  :whistle:
Post by: 85RZwade on August 24, 2021, 10:59:06 PM
Yup. You have to look at it as: what motivates you? What's easier, removing a few pounds from you, or the bike? Be well and healthly, my man!
Post by: pidjones on August 25, 2021, 08:58:30 AM
BEFORE you paint, make darn sure it is clean inside and leak-tight. Sucks to get a nice paint job only to discover a pinhole afterwards (from one who knows).
Post by: RustyRD on August 25, 2021, 09:14:18 AM
You are so right. Had a kz1100 that was full of rust and had pinholes all over. Thanks for the reminder to double check.
Post by: RustyRD on September 25, 2021, 09:28:40 PM
Had the chance to work on the RD today, so I prepped the tank and fender for primer. Still need to make a choice of color.
Post by: Gil Gallad on September 26, 2021, 07:55:49 AM
being as most people seem to favour the kenny roberts colours, why not the petronas moto gp yamahas from last year? always liked the colour of the petronas turquoise  :haw:
cheers, gil.
Post by: m in sc on September 27, 2021, 10:41:36 AM
Quote from: Gil Gallad on September 26, 2021, 07:55:49 AM
cheers, gil.
HAVE TO AGREE. Yellow and black has been played. to. death.  :ohdear:
Post by: RustyRD on September 27, 2021, 09:48:13 PM
I agree, I am leaning to a gunmetal gray and black. I am still looking at different colors and schemes, and a burnt copper is in the running also.
Post by: m in sc on September 28, 2021, 03:09:33 PM
if you do gunmetal grey and black, might want to do a thin white outline of any graphics. just spitballing.
Post by: RustyRD on September 28, 2021, 09:31:08 PM
Yeah something to give more of a defined line.
Post by: RustyRD on February 14, 2022, 08:00:55 PM
well had some time to do a little work on project, weather was great so I took it out, made a gearing change and check jetting, now I want to rework my seat pan. so off into unfamiliar waters again. Gearing was too low, dropped three teeth on rear, not having to try to keep up with rapid shifts.
Post by: NoRiders on February 15, 2022, 12:40:37 PM
Looks good...what's the plan with the seat pan?
Post by: m in sc on February 15, 2022, 01:18:03 PM
piece of advice on the seat design: make sure the pan doesn't sit flat on the rails all the way along them. support it front and rear at 4 points if you can so it 'gives' a bit riding it, your ass will thank you.
last one i did i made out of aluminum and used insulated 'p' clamps around the frame tubes at the front and rear and the pan gives about 1/4" before it hits the rail in the middle and its way more comfortable than it should be for a thin seat.
Post by: RustyRD on February 15, 2022, 06:17:04 PM
Thanks for the words of wisdom, I thought I would try to use a rubber bumper attached to the pan base. But what comes to mind after you have stated that is, allowing for the height of the bumpers in the overall design. I want to try to take into consideration all the parts needed to keep rework at a minimum. I will be using fiberglass to construct the pan, I have a pan now I just am not real happy with it, I want something that I will not be ashamed to show someone.  :celebrate:
Post by: rdshaw on February 16, 2022, 06:48:31 PM
My 2 cents make sure you seat is at least 18" above peg.
I try to get as close 20"  as possible ........I have measured a lot of bikes   I have done 17 a few times and it's too low for hips in .my experience
Post by: RustyRD on February 17, 2022, 10:00:40 PM
Thanks for the info,I will check the distance from seat to pegs, I have on occasions have had the cramp at the hip and have to stretch out my leg to relieve it.  I want to keep foam thickness as thick as possible
For comfort and also keeping looks in mind also. I want to maintain as much comfort as I can for what it is.
Post by: NoRiders on February 18, 2022, 05:57:34 AM
My two cents worth....
I used layers of cheap 15mm yoga mat (various thicknesses are available), it's closed cell so resists 'sponging' water and offers a level of comfort even at low profiles such as 30mm. Probably want more depending on your weight and ride duration, but as a maleable material that's relatively easy to work it might do? Even a triple layer is only 45mm and would still offer a low profile seat compared to regular foam.
I fashioned my Suzonda seat pad from 2mm alluminium sheet (it sits on a fibreglass unit, so really only to hold the form of the pad), glued two thicknesses of 15mm yoga mat and worked it with 40 grit to shape it. If it was a rough n ready tracker bike the yoga mat could've been left in it's raw state, but I shaped it for the trimmer to work his magic.
Raw, double layer shaped to some extent. The forward seat/tank area was formed using a cut down ear defender casing to form a mouth to clear the rear tank mount.
(https://i.imgur.com/NwYHjeq.jpg)
Turned out nice swathed in William F1 blue suede with matching tank pad too.
(https://i.imgur.com/HDUn3Xu.jpg)
I have a thing about how the seat 'mates' with the tank....so many builds have gash gaps and illfitting seats....they make up a large % of the overall aesthetics and demand thought and pro finishing IMO.
Post by: pidjones on February 18, 2022, 09:40:55 AM
On my GL1000 build, I wanted a cafe appearance with GL comfort. A fiberglass GL1000 replica seat pan showed up on ebay and I snatched it up. Layered 1/2" rebond carpet padding in the shape that I desired and had an upholsterer cover it with material I supplied.
(https://uploads.tapatalk-cdn.com/20220218/cde6705f7512366c695135a6f599457e.jpg)(https://uploads.tapatalk-cdn.com/20220218/7a1df8eb73f2cf5a178872fe34253cc1.jpg)(https://uploads.tapatalk-cdn.com/20220218/cf9e5e17e2df73bfaed8da2338e77cdd.jpg)
Post by: RustyRD on February 19, 2022, 09:27:05 AM
Thanks for the pics and ideas, how was upholstery attached? rivets, glue, staples.
Post by: 85RZwade on February 19, 2022, 07:38:18 PM
Those are two amazing custom seats, I love the ideas  :thumbs:
Post by: RustyRD on February 19, 2022, 08:56:42 PM
Wade I agree, two well done seats, and again guys thanks for some ideas on the subject.
Post by: NoRiders on February 20, 2022, 01:54:17 PM
Thnx....by the looks underneath, the suede is only glued to the alloy. I had bought toothed metal gripper strip but the upholsterer preferred glue for suede....it's turned out absolutely flat underneath.  Tidy.
Post by: RustyRD on February 20, 2022, 05:23:44 PM
Thanks, Tidy for sure,it looks great.
Post by: pidjones on February 21, 2022, 07:46:24 AM
Mine was stapled (although I requested both staple and glue). I think glue alone would have worked fine. Contact cement is very powerful in that application. BTW, electric carving knife for rough shaping, but DON'T USE THE WIFE'S! They are cheap on ebay or thrift shops.
Post by: RustyRD on February 21, 2022, 08:03:00 AM
 :whistle: your right, I had to buy my wife a new one after being found out :gentleman:
Post by: RustyRD on May 18, 2022, 04:46:51 PM
spent some time working on my seat project of the RD today. Still need additional layers, however I finally got started on the new base.
Post by: RustyRD on May 30, 2022, 08:51:31 PM
working out a quick release for the seat, and it was not as difficult as I first imagined. I still have to attach the tab to the pan.
Post by: m in sc on May 31, 2022, 01:41:04 PM
very nice work.  :olaf:
Post by: RustyRD on May 31, 2022, 09:44:56 PM
Thank you. The latch itself is from a Kawi z900rs. I had a kz650 project dropped in my lap. Anybody oh the forum running these?
Post by: RustyRD on December 04, 2022, 07:39:06 PM
well it has been a while since I have any time to devote to the RD, to make up for it I bought it a new set of pipes. Jim Lomas stainless with stainless silencers. John from Economy was so helpful answering all my questions and concerns and shipping was two days. WoooHooo.
Post by: RustyRD on December 04, 2022, 07:45:24 PM
one more, the seat is still on the list but progress has slowed and time always slips away.
Post by: RustyRD on February 08, 2023, 05:09:27 AM
ok, so the seat is proving to be a challenge for me but I will not give up :bang: a different approach than what I had started with. still more foam on the way to help get to the end.
Post by: RustyRD on March 01, 2023, 04:35:52 AM
I am working on some different combinations with the seat base. Does not speed things along when you only work on it every other weekend :umm: Here is the current state of seat construction.
Post by: m in sc on March 01, 2023, 10:03:29 AM
looks pretty good. reminds me of an old F11 kawi i had w that tail.
Post by: RustyRD on March 01, 2023, 08:27:52 PM
I forgot about that bike, I would like to have one , according to my wife, I want all the motorcycles :whoop:
picked up another stay today, a 1982 XR80, can't pass up a deal. The seat will continue to challenge my skills in the area, however I am determined to complete it myself and hopefully not embarrass me either.
Post by: RustyRD on March 14, 2023, 08:11:44 PM
Decided to add a larger ultrasonic cleaner to the tool arsenal. I hope it holds up and does not let me down. I look forward to being able to use it on some of the larger parts. I plan on using simple green solution it this device. what do you guys use for cleaning solution in ultrasonic cleaners?
Post by: Kawtriplefreak on March 15, 2023, 01:03:24 AM
I use Krust Kutter from Walmart for degreasing full strength. I use a 50/50 mixture of Berrymans carb cleaner and WD40 for cleaning carbs, the latter courtesy of M in SC. I fill the ultrasonic with plain water and use a big pickle jar or similar wide mouth container filled with either solution floating in the water and it works like a champ. My cleaner is a 30 liter Vevor.
Title: Re: RD Monoshock ninja susp. swap
Post by: RustyRD on March 15, 2023, 04:54:10 AM
Thanks for the info, this unit is a Vevor 30L also. Have read that some of the forum users have had good luck with Vevor. I decided to go with the 30L to avoid the regret of buying the smaller ones.
Post by: sav0r on March 15, 2023, 09:04:19 AM
I have the 15L version of that tank and at the car shop we have the 30l one. They both work great. My 15l has seen some shit, including my dog getting caught in the cord and pulling it off the work bench. I had to pull it apart and solder up a few connections to get it to work again, but after at least 5 years of having it, I find it pretty invaluable. It's an extra set of hands cleaning while I get to do other stuff.
I like the Simple Green HD concentrate. It can be found at a Home Depot. I find it works great on castings.
Post by: RustyRD on March 15, 2023, 09:10:03 PM
I bet that scared the poor dog silly. I feel like I may have made a good purchase. I also purchased the simple green from Home Depot. Thanks for the feedback
Post by: RustyRD on May 10, 2023, 08:30:22 PM
Quote from: Kawtriplefreak on March 15, 2023, 01:03:24 AM
I like the idea of the pickle jar with solution and just water in the ultrasonic.
Post by: RustyRD on November 21, 2023, 07:54:42 PM
ok I could not help but place the RD 350 tank on my other project and I think I like the looks of the 350 tank over the 400 I had in place, tinkering with a different seat and tail section also. I got the tail and seat for my R5 with 400 engine now I am having mixed thoughts.
Post by: m in sc on November 21, 2023, 09:36:20 PM
it looks better on this bike (the seat)
 :twocents:
Post by: RustyRD on November 21, 2023, 09:57:24 PM
Thank you  I think I want to swap tanks now also, might need to check and see who may have a spare 350 tank.
Post by: 71R5JPAR on November 22, 2023, 01:11:52 PM
350 tank looks better as it goes well with the front fender you chose.
Post by: m in sc on November 22, 2023, 01:26:45 PM
imho, THAT TAIL LOOKS BETTER W THE 400 TANKS. .02
Post by: RustyRD on November 22, 2023, 04:07:39 PM
thanks to all for the input, I am excited to have a new toy to work with this weekend. :whoop:  :whoop:
Post by: 71R5JPAR on November 23, 2023, 12:15:35 PM
New toy?!
I looked through your entire thread and didn't see, maybe I missed it, but what size rear tire were you able to fit? Did you need to do anything for chain clearance (offset countersproket?)
Post by: 85RZwade on November 23, 2023, 12:21:32 PM
Looks like a 120
Post by: RustyRD on November 23, 2023, 02:24:24 PM
new toy is tail section and upholstery. Wade... you win. its a 120 Pirelli very slight chain misalignment but has not been an issue in place and not fussing been in place for a while not exactly sure of milage but has not been enough to warrant my snagging a offset sprocket..oh these are 16" wheels so far handling has been good, part of it might be having a wider up right handlebar has help control the steering quickness, I have made adjustments to bring trail closer to stock. Bike has seen about 85mph in current configuration without any unwanted evil feedback.i still may do a swap to 17" wheel and tire combo, just not yet. I want to get more details ironed out
Post by: 50gary on March 09, 2024, 10:30:49 PM
I love my L&R Wave ultrasonic cleaner, different solution for different items sometimes just hot water will clean very well the mechanical action is the main thing.  Sidebar note: At U of M (Michigan) they are pioneering super high freq.(120hz) ultrasonic action to disintegrate cancer tumors, liver cancer is the first cancer to be approved by the FDA for ultrasonic treatment.  Zero side effects, typical treatment time is just one to eight minutes with zero pain.  I have rectal cancer so this is important to me.  I hope and prey that is came become the future of many cancers treatment, radiatio, chemical surgery are brutal and I can speak for recent experience.  Sorry to hijack but this is why I've been absent from 2T World.
  Cheers, 50gary
Post by: RustyRD on March 13, 2024, 07:59:08 PM
no worries, I spent some years working as a field service tech in the Biomed field. This info will make me want to research this info.
Post by: RustyRD on March 15, 2024, 11:26:35 PM
I did not read your reply thoroughly, I wish you well with your procedure.  Best regards.
Post by: RustyRD on April 06, 2024, 10:23:04 PM
I have been distracted and not working on my 350, shame shame shame. I have spent today working out the mounting of the seat and various details. Need to work on the tank and pick a color for paint, I am getting tired of looking at primer. I only have myself to blame.
Post by: 71R5JPAR on April 11, 2024, 11:24:28 AM
Don't be so hard on yourself, you are doing a great job with this project! I'm always excited to see an update on your bike, but understand these custom jobs take some time. Working on my own custom R5 and it's hard to find a balance of project progression and other life responsibilities.
Post by: RustyRD on April 13, 2024, 09:59:44 PM
Completely understand balance of time. Thanks for encouraging words, I have discovered that the kz1000 and kz650 triple clamps will work with my front end swap. Either one will produce more trail than the ninja 250 triple tree. This can be helpful in making it more stable at speed.
