lights dimming with turn signals on
Started by rd400canuck, April 16, 2020, 03:29:44 PM
rd400canuck
Just wondering if thats normal or could I have not worried it correctly in the headlight bucket. I have LED head light and tail lights but the turns signals are normal bulbs. I can easily see the head and tail light dim every time the turn signals flash on. There's no way they little bulb is dropping the voltage like that on a freshly charged batt to cause the other lights to dim a little.
Any ideas?
forexer
does this happen when the bike is running or are you checking it with the key on and bike not running?
If it's happening when its running increase your RPM's and see if it helps - if it's doing it with key on and bike not running than this is completely normal.
