Countershaft (and etc. ) seal check
Started by MRDRcycle, July 21, 2020, 05:46:26 PM
MRDRcycle
As long as the bike is in neutral, I'm guessing this is ok to start with the side cover off and clutch disconnected. I%u2019m thinking it would be good to see if the seals are leaking before putting it back together.
Meh... Nevermind. I just put it back together. Going to ride it around the block and see if it leaks. Easy enough.
