Brown, brown/white and black wires question
Started by patastinky, October 08, 2020, 02:50:18 PM
patastinky
Hello
Trying to figure out where do these hook up ? Any idea? These are under the gas tank.
https://imgur.com/a/d4hT2KZ
Brown and brown/white are flasher relay
Black should just go to ground
patastinky
Quote from: rodneya on October 08, 2020, 02:57:52 PM
Should I then hook up the brown and brown white together? I'll ground the black. Thanks.
Do you turn signals and a flasher? If so, then like what rodneya says, the brown/white and brown go to the 2 wires of the flasher.
bn/w is the feed from the flasher to the turn signal switch.   brown is switched power. black is ground.
patastinky
Thanks guys. Will do that. Getting close to starting her up.
