Rd400 wont start on ignition /relay
Started by rd400greenhorn, June 28, 2021, 06:54:16 AM
rd400greenhorn
Yes so i was testning wiring in the back on the rear brake light.
Everything works Besides that and now All the sudden i Cant hear the relay switch when tuning the key over and No light. Its dead.
Battery is fully charges and it seems All fuses are intact.
What the??
rd400greenhorn
Okay wtf.
It lights up now.. 🤔 Will investigate
rd400greenhorn
So iam blowing fuses by trial and error on the few remanining wires in the rear 3ne or the bike.
Just Cant seem to hack the config of tail light on and rear brake switch activation.
Its either rear light on, front brake light works
Or rear light off, rear brake light work
rd400greenhorn
So there is only 2 wires under the seat that goes to the tail, that are power in as now.
The yellow has when i acticatw the front brake and the Brown next to it, is constant 12 v when ignition is on.
And in the headlight it seems as if i have connected the front brake right. One wire to yellow/green ( this ends up yellow in the back) and one wire to oil lamp i believe it is?
