Stock R5 case crack advise sought
Started by Greaser Greg, February 04, 2020, 10:00:39 PM
Greaser Greg
Is this thing garbage? Run, repair, or replace?
Barrie
The only way you'll know for sure is to pressure test the motor and spray it down to see if it leaks there. Cracks in engine cases happen and any good local welder can take care of it if it indeed is a crack. But it could just be a casting flaw too.
Greaser Greg
#4
Great info,thanks all! There is nothing similar visible on the other side, so I don't think it will leak. Was more worried about a catastrophic failure.
So when the case cools the material shrinks more in that area to create a void? Or impurities in the casting material fall out eventually, leaving the space? Inquiring minds....
Plasticman
All my RD400 cases have "cracks" like that in various places.
Rob
1976 - RD400 - road racer
Greaser Greg
