RD400 Rear Brake Options
Started by RattlecanResto, March 22, 2020, 12:35:29 PM
RattlecanResto
Wondering what any of you all may have used as a replacement rear master cylinder?I will assume a mounting bracket will need to be made. Any other mods?
Thanks
Seizer
RattlecanResto
Looking for an affordable option
Quote from: Seizer on March 22, 2020, 12:43:29 PM
https://hvccycle.net/yamaha-rd400-rear-master-cylinder-hvc200220/
Here's an option. Not cheap but allows you to keep the stock caliper.
Just curious, what has the master cylinder have to do with the caliper? Except for bore diameter requirement? I would think mounting lugs, reservoir size & style, and pushrod dimensions are more important if stock pegs and brake pedal/linkage are used.
youre right, its just bore size.
TBH, i use a 12mm but i have rearsets with a short lever  :twocents:.
RattlecanResto
Keeping everything stock. Original bore size is 14mm?
I've forgotten what the rear is... the front master is 5/8's
C
Seizer
Quote from: Dvsrd on March 22, 2020, 07:37:55 PM
It would've been more to the point if I had said that I'm using this MC with the stock caliper.
Barrie
There seems to be a good selection on Ebay.com, about 50,000 !
