Quick throttle with stock carbs and oilpump
Started by rd400greenhorn, July 29, 2020, 03:44:17 PM
rd400greenhorn
Yeah so
Any advice or recommadation?
Its just i Want a quick throttle on my ' stockish' build.
Stock carbs with oilpump,  Any tips?
For a yamaha rd400
I assume you have a plan for kill switch and light switch?
rd400greenhorn
#2
I plan on using stock controls as well offcourse
get some pvc tube and make a ring around the throttle tube, glue it on with pvc cement. seen this done a number of times on other bikes.
I'm interested to see how this turns out.
I go back and forth on wanting to put bigger carbs on mine. I know i would want a straight pull throttle, but want to keep the stock switch and make it all look decent.
That's one of the things preventing me from doing it. Among others.
Quote from: rd400greenhorn on July 30, 2020, 12:45:18 AM
You can do as mark said and maybe get away with using your stock control but why? Just get a Magura 314 throttle and that can be made to work with your cable, you will have to eliminate the light switch but who cares, just wire it so its on all the time like it should be anyway. You will also loose the stock kill switch but that's no big deal either, just wire in a new one, I went with an MX button style on mine.
