Hot ticket for the rear brake master cylinder
Started by EE, June 24, 2021, 01:42:14 AM
EE
Hey guys helping a friend and his rear master cyl is frozen does anyone make a rebuild kit anymore i know they were getting scarce a while back. Ed
IF i recall correctly and your looking for a RD400, Chuck says a FJ one works. If I recall correctly...
Ed,
Since the OEM RD400 rear kit (1A1-20000-50-00) is NLA from Yamaha here are the options:
1.  Economy Cycle OEM kit
2.  Economy Cycle repro kit
3.  OEM substitute: Yamaha 2YK-W0042-50-00 (from FJ1200, Wolverine, etc.)
    (For a RD400 you can use the spring and rubber parts, but not the piston)
4.  If you need the piston then the one mentioned above by DesmoDrew is one to get
Plasticman
This needs to be written up and put in the Tech section for all to reference.
1976 - RD400 - road racer
Quote from: Plasticman on June 24, 2021, 02:04:37 PM
Done
I've used the Yamabits kit on a couple and they worked out ok. Their kit comes with all the internals including the piston.
