Steering Damper on RD400
Started by KANDY, July 05, 2021, 08:09:51 PM
KANDY
Hi All,
Does RD400 has stock Steering Damper like RD350, My Handle is kind of turning too much and touching to the tank.
Buying aftermarket are only are the options ?
1974 RD350
1981 RD350LC
1977 RD400
1980 RD400 Daytona Special
Damper only stops head shake, the steering stops are meant to stop the bars hotting the tank. Maybe take a look if they are damaged - lower triple and bottom of the stem.
not stock but a common upgrade. your issue is the steering stops though.
KANDY
Quote from: rodneya on July 05, 2021, 10:42:14 PM
Yes, bottom of the stem, stopper is damaged, allowing the handlebar turn too much.
1974 RD350
1981 RD350LC
1977 RD400
Yes, pretty common problem. Must take a very small bump to damage them. I've even considered dilling and tapping mine to add adjustable stops. For now, a wire tie tight over the bad side and super glued in place. You know you have the problem if your tank has dents lining up with the upper clamp nuts.
KANDY
#5
Quote from: pidjones on July 06, 2021, 07:58:40 AM
I've even considered dilling and tapping mine.
Considering this option. Or go to the Welder and have a stopper tig welded to stop the extra turn.
1974 RD350
1981 RD350LC
1977 RD400
ive done both in the past. drilling and tapping was easiest unless the frame is bare, if that, then weld and repair correctly.  :twocents:
These adjustable stops from cognitomoto are pretty sweet
