Intake manifolds?
Started by pdxjim, August 21, 2021, 04:52:42 PM
I think when building my LC motor, I hogged out too much of the ID of the intake manifolds to fit the PWK's and match up with the Vforce3 cages.
Basically, I removed the step that the carb butts up against inside the manifold so the carb goes in a bit further and fits more securely.
My theory is this step from the 28mm ID of the carb to 34mm OD of the carb/ID of the manifold is causing turbulence, or slowing the flow at low vacuum/RPM, and causing tuning issues down low.
Does this sound plausible?
If so, which manifolds do I need to replace them with so I can start over?
Needs to fit the larger RZ crossover, and ideally have no ears so they fit flat against the Vforce3 cages.
there should be a lip seal that the carb 'snaps' into in the intake. it doesnt need to go further than that. id get some upp intakes from john at economy.
I really like these, but it looks like they are out of stock.
Dont have a crossover, but it is basically just a gimic that adds places where you van get an airleak.
https://drivelineperformance.com/billet-intake-manifold-kit-stock-26mm-28mm-carbs-carburetors-yamaha-banshee-350/
