RD350 oil seals part #
Started by Pravin, September 05, 2021, 07:47:02 PM
Pravin
Hi all ,
Tried googling... Do we have a complete list of rd350 oil seals and part numbers ?
Regards,
Pravin
Are you looking for engine seals, or for the entire bike?
OEM or aftermarket?
You can order kits or individual parts from John at Economy.
I was able to whip this up in a couple minutes (no google required)  :wink:
RD350 Engine oil seals (1973-1975) – OEM parts list
Left crank seal
Yamaha 93103-20076-00 OIL SEAL, SW-TYPE
Right crank seal
Yamaha 93103-40077-00 OIL SEAL
Yamaha 360-11526-00-00 SEAL, CRANKSHAFT (discontinued)
Countershaft (sprocket)
Yamaha 93102-35109-00 OIL SEAL (SD-35-62-6 HS)
Shift shaft
Yamaha 93102-12321-00 OIL SEAL (SD 12-22-5 HS)
Clutch push rod
Yamaha 93109-08061-00 OIL SEAL
Kick starter shaft
Yamaha 93104-20007-00 OIL SEAL, SO-TYPE
Tach drive
Yamaha 93210-13016-00 O-RING
Yamaha 93210-07100-00 O-RING
Oil pump shaft
Yamaha 93101-10002-00 OIL SEAL
Neutral switch cover
Yamaha 93210-29196-00 O-RING
I usually reference CMSNL and Partzilla for numbers like these, 'cause I'm used to IPLs. I think Russ just has them memorized.
Pravin
Recently found megazip.net and it seems to be a good resource
Quote from: 85RZwade on September 07, 2021, 10:38:30 PM
Careful with them. They like to take your money, then confirm if they have your part or not, then issue you a refund if not.
i just order full kits from john when i can. good to have spares around.   :twocents:
Quote from: Striker1423 on September 08, 2021, 01:42:44 PM
Thanks for the warning! I'll use them for reference only.
