Brake Torque arm bolt
Started by Joshua, January 15, 2022, 07:36:24 PM
Joshua
Does anyone know where I can get a torque arm bolt for the brake support arm on an RD400.  Apparently, I can't tighten bolts or put a pin in. . . . I can't find one anywhere.
Thanks.
Yup. Yambits is legit. They'll get you parts in around 3 days from the UK. Used them often.
I had my front motor mount bolt spin out on me back on the first rendition of the 350 top end. Heard this loud metallic spinning noise, thought I was killing a crank bearing initially, so I looked down and here's the motor mount bolt exiting stage left lol. I managed to stop and put the bolt in my pocket for a trip to Tractor Supply that was 3 miles away. Lucked out there.
Joshua
