RD shifter leak repair
Started by soonerbillz, March 15, 2022, 03:02:06 PM
This guy says he has a fix for Rd shifter leaks.
I didn't know this was a big thing.
Is this also a R5/YD7 problem too?
And is this repair he is sporting a real repair or just a short term solution?
https://www.facebook.com/groups/1553233251641230/permalink/2817393805225162/
this was talked about earlier. IMHO, it snot bad.. and will def move the seal out past the 'wear' point that develops on shift shafts.  Ive never had that big a problem, but i have seen some work out shift shafts where the seal sits.
I bought one. It's a well=built piece of kit. Also, the shipping was fast. Got it in about a week after paying him. Air freight.
Not only moves the seal out on the shift shaft, but also takes up any movement in the shaft due to worn bushings.
