Powerdynamo installation issues
Started by motosapien, May 05, 2019, 07:27:27 PM
motosapien
Hi,
I have run into an issue while installing powerdynamo on the RD350.
I have spark with ignition key in the ON position. All lights work except the headlight.
Need help in sorting this issue, I have wired the kit as per the manual.
Thanks in advance
Some Gammas, RZ350 and Hybrid Ape that Ed T is building since 2018
Do you have a relay installed On the blue stop wire from the cdi box? Is the relay connected correcly, i.e normally closed, connecting blue wire to ground? And open with ignition on?
motosapien
