Filtering Oil
Started by Milan, September 09, 2022, 11:25:27 AM
Milan
So i posted a while back about a whining noise in my KH250.
I had just put in new transmission fluid.
So I drained it, and replaced the primary gear & clutch gear.
I put in 75w-90 gear oil.
Ran it for about 5 minutes
The gasket leaked.
So I drained the oil back into the bottle.
It came out dirty.
Even after the trany oil flush.
So I took that oil & ran it thru a filter using a mask.
It came out pretty clean, I was surprised.
so, being its new, going to use it.
M
Site is not letting me post a picture of 3.9 MB
I will try later
https://www.dropbox.com/s/tnrz5ahos35essc/20220908_190203.jpg?dl=0
no reason it wont be fine, ive done that for sure.
as a side note, these are the attachment settings. As long as it fits these requirements it should load. if not, you're probably doing something wrong.
