push rod bearing
Started by kramdua, February 02, 2023, 01:16:28 PM
kramdua
does anyone have the diameter of the push rod ball bearing for a 1975 rd350?
thanks,
8 year absent.
back in action.
virginia.
8mm im pretty sure (like99%) will work. as long as its the same size or just under the rod diameter. if its 8mm, then 5/16 should work.
kramdua
i measured the push rod and it was 8.67 mm so i am sure 8mm will work.
thanks,
8 year absent.
back in action.
virginia.
Parts book says 5/16"   Yamaha 93505-16006-00 BALL
Same part for all RDs and many other models.
(= 7.9375 mm)
kramdua
thanks for the input.
you have to love ace hardware or true value. their hardware and small parts section blows the big chain stores away.
8 year absent.
back in action.
virginia.
i have a box of those for that same reason.  :whistle: yup. you'll find the original about a year from now under something  :dawg:
kramdua
i always take little things like that and tape them in making tape and hang them on a wall. not there so in about a year i'll step on it.
8 year absent.
back in action.
virginia.
Quote from: kramdua on February 03, 2023, 10:36:23 AM
My local Ace is my go-to place. They've got nearly everything! Hillman Fasteners FTW :thumbs:
Usually when I'm in there looking for something I'll end up talking to another customer and it turns out they're also buying motorcycle hardware (although usually for a Harley or adventure bike), or sometimes it's for a hot rod build. Some interesting conversations happen in the hardware section there.
kramdua
usually the people that work there are friendly and ready to help. i can't make this stuff up. there is an older employee there that is deaf. i couldn't find the drawer that had the ball bearings. he gave me a notepad and i wrote down steel ball. he wrote back what size.
amazing.
8 year absent.
back in action.
virginia.
local place we had here had reverse thread metrics in stock.   :eek: went there for like 15 years. unfortunately, they retired.
