Carb Slide Screws
Started by 2steve, March 28, 2023, 08:34:14 PM
2steve
Went to raise the needles with a 1/2 step washer this evening and realized it would be wise to order fresh screws. I have JIS screwdrivers and one of the screw heads is still a little too far gone.
Those two screws that fasten the "clip" assembly that holds the needle down in the slide and also grabs the end of the throttle cables... RD400 VM28 round slide.
Looked at JetRUs, eBay, Yambits, etc.
Where can I get a set of 4?
Your local Yamaha dealer should have them, they're a current part. 98580-03010-00 SCREW, PAN HEAD
Or you should be able to get them at a local hardware store. I believe they are M3x10 (measure the OEM ones to be sure).
Also Economy has them: Yamaha RD400 C/D/E Throttle Slide Screw/Washer Set
2steve
Excellent!
10mm long looks exactly right.
I'm going with Economy Cycle.
Thank you!
